Copper accents are always sick.
Back from death- the revival of a 74 BMW 2002
My thoughts exactly. Post-Apocalyptic is the look I'm going for.Originally posted by CubbyChowder View PostI just thought you were already set on the car's color choice so I was a bit confused, but I know how that goes. I toss color combo's for my '02 around all the time. That would definitely be a cool combo though, given the raw interior. That would sort of give it a post-apocalyptic, almost steampunkish kind of look. With the wild rear fenders and raw seats, I think a rugged/raw look is what you should be going for. All my opinion, of course.
Agreed. I love me some copperOriginally posted by floatingdino View PostCopper accents are always sick.
Cant you just get a valve that will measure up to 200psi and then hook the tank up to an air compressor and pump air into the tank till it hits 200psi? Maybe put it under water or spray it with soapy water to see if it leaks.Originally posted by rhoderacer View PostThanks, I keep changing my mind but I think flat olive green is going to my final decision. I'm having trouble finding a place to get it pressure tested for 200psi. The tank says it can hold 500psi but that was a long time ago.
I guess i could do that, but the whole point of getting the tank pressure tested is so it wont explode in my face. I know the odds of the tank actually exploding are slim but i like the way my face looksOriginally posted by deutschman View PostCant you just get a valve that will measure up to 200psi and then hook the tank up to an air compressor and pump air into the tank till it hits 200psi? Maybe put it under water or spray it with soapy water to see if it leaks.
150 is probably still to high.Originally posted by CubbyChowder View PostWhy 200psi? Correct me if I'm wrong, but I think anything over 150psi is usually unnecessary.
Well I dont know put it under something or behind something while testing. if anything pops off it will most likely be a fitting, or a seam will crack. I dont see anything actually going BOOOOM! Just make sure it bolted down to something so it doesnt rocket off if something pops.Originally posted by rhoderacer View PostI guess i could do that, but the whole point of getting the tank pressure tested is so it wont explode in my face. I know the odds of the tank actually exploding are slim but i like the way my face looks
