Perfection!
bmw e30 on bbs e30-->'90 318is
Put out the spring and the sway bar... then you can see in where the rim is when its in the right position.
That's what I was coming back to say. Take the spring out and disconnect the sway bar or jack the control arm up to where you want it to eventually sit, then you can plan tyre size accurately. Also you'll see the poke will be a lot less if any at all when lower.Originally posted by WhiteLove View PostPut out the spring and the sway bar... then you can see in where the rim is when its in the right position.
Again, that is gonna look great
