Another Mercedes W115, 1969
ahhh yeah !!! looks promising
So today was disappointing. After working hard for 2 months to get the car done, I had it ready last week (less the rear shocks and height sensors) so I test drove it with no major issues except a couple of small leaks. Today I was planning to go to a big local show, as soon as I left home with 3 passengers the left back wheel started losing air. The controller started flashing meaning the air compessor couldn't turn because of some fault. I stopped, my dad went home and brought a compressor to pump the air up so I could drive it back. Put it in the garage, couldn't take it to a show. Oh well such is life, I have some major flaw in how I routed the rear air lines
Here are some crappy phone pics I took while trying the car this week. Next I'll see whats wrong and finish the shock mounts etc
Yeah its aired out, downpipe touches the floor, it looks lower in real life...I'm new to air ride and I still need to figure out some problems I kept on having this week :S I like your too, it has attitude
I've been trying to sort out the air line routes this week. I added a plate to tilt the manifold at an angle
giving more space for the lines to turn without getting pinched. I also added some ptfe bushes which are longer than grommets for the rear lines. The grommets weren't holding well since the holes are drilled on a curved plate
thanks...well, since you have air ride already the hoses are probably laid out well. That was my major problem, the hoses need long bends and I didn't lay it out too well the first time around since I didn't have the hoses in place. Its a learning curve. In the first pic with the carpet the manifold was shooting straight down toward the trunk floor with hardly and room for the hoses to turn and clip into the fittings
I would mock up the manifold first as well as find a good spot for the compressor and tank. I used blocks of wood etc to mock the heights
