Any updates ?
Chase's 73' Merc w108 Build Thread
16" 3 pieces
Originally posted by mike-81-240d View PostI enjoy BMW's (your E90), but I mainly love old mercs (my first three cars were Mercs). I am genuinely excited to see how this turns out. Come the end of the month I'll be searching for a W108, W114, W115, or another W123 to fix up. I miss my Mercedes days.
BTW does it have conventional rear suspension, or SLS?
Hi:
I have these rims in my W126 sec .I have w108 steering wheels on the same W126 .
But ,the most wanted thing is your W108 4.5 .
I've been so busy with my new job and working on this thing that I've been neglecting forums in general. I poke around from time to time but no where near what I used to. If you want to follow my my build and our builds at work follow me on Instagram @cdkieke.
My build has taken a radical turn since I started my new job at a hot rod/restoration shop. I'm learning more than I could ever imagine, and learning from a very talented individual.
First off I chopped my front end off.
I wasn't completely satisfied with it and I plan to do something more factory looking. But I am not to that point just yet.
I've also since completely gutted the car of all wiring, motor, and mechanical bits. The engine bay has been completely shaved/redesigned for the small block Chevy being swapped into it.
I'll try to update this thread more regularly.
Good stuff, I'm glad you're finding time to work on this !!
Meh, chevy engine in a classy car is wrong... u can pick up a totaled amg at COPART, for a few grand and strip it and put a modern day engine from a newer benz if you got that far. chevy motor, in a benz, i dunno, its white trashy....
take notes..
[ame="http://www.youtube.com/watch?v=4z0_Y_yPXa0"]1971 Mercedes-Benz 280SE 3.5 vs. 2012 Mercedes-Benz CL63 AMG - CAR and DRIVER - YouTube[/ame]
Update!
Been hard at it. I was out of commission for about 3 weeks with a knee injury, but still got quite a bit done since I posted last.
The bodywork in the engine bay is nearly finished. Just a few spots that I had to weld on need some attention but it's getting there.
In between everything I've been bead blasting any parts I think I may be using an getting them primed.
This is some of them. I love having a blast cabinet
And lastly I finally dug into redoing the front end. I had been procrastinating the living shit out of this. Thankfully it went smooth and I am much more happy with the results this time around.
The first time it took me like 200 hrs, including bodwork, or something like that lol. I put in 2 full days this weekend and all that's let before its ready for bodywork is finish around the grill surround. Sigh, live and learn.
My ace in the hole was a front lower valance from a 70 Mach1 Mustang. The center section will be removable and separate from the fenders.
Got my new pedals all mocked up (note third pedal, heh). pedals are from a Subaru BRZ and I used a portion of a crash bar from a 350z as the mount/support for the pedals.
I was going to stick the booster in the wheel well but after mocking everything up it was just to close for comfort. So I opted to make a 90 degree under dash setup instead. I just need to finish up the linkage, mount the clutch master, and add the return springs/stops for the pedals. It's been a bit of a mind fuck getting the pedals right. Lol
I have been a bunch of other tasks that I should be wrapping up here shortly but I can only go so far without the motor. The motor, yeah about that.... Had a serious change of heart and will be throwing an inline 6 in it. I just love the simplicity of a nice clean looking I6, And I dont need a ton of power so I'd prefer to stay NA.
Have a few different options I have been looking at..
L28 with triple webers or ITBS
2jz
Or maybe something bmw
I would look at something mercedes but there isn't jackshit for anything with manual trans that I can find. If you have any realistic ideas throw them out there. Maybe there's something I am missing. Cheers.
Another little update, I cleaned out the inside real good and scuffed all of the floor panels. I used por15 in some areas, and then undercoated everything other than a few spots that I needed to do a bit more work on.
Final finish will be paint over the undercoating leaving a nice speckle finish.
Somehow I think an toyota UZ engine would fit this car quite well... A nice v8 with lots of torque... And a lot cooler than an American v8 in my opinion.Originally posted by aLaFleur
I've decided the best way to deal with rust is to just embrace it.
