Thank you=)
I was out Saturday and got all of the bushings removed. Their sleeves were the worst. I used an air hammer to cut them out of the subframe. I have to use the air hammer and a torch to cut the sleeve out of the diff cover. I didn't get much besides that done Saturday. I took too long to get those out. I did end up stripping the trailing arms completely down.
I then picked up some brake cleaner and a rust/paint stripper wheel so that I can prep the arms, subframe, and block for paint=)
Yesterday I worked on something that I have been putting off for weeks. Removing the lower half of the fusebox was where I stopped the relocation process. Yesterday I decided to do something about that.
I started by removing all of the relays from the lid:
I was then about to remove all of the wires for the fuses, but noticed something. Each section of fuses is clipped into the box. They were pressed in there really good, but I managed to get them out.
I'm not sure if anyone has noticed this before, since I see people just stuffing the whole lid under the dash. That looks half assed to me. I will be making a mount for just the fuses and relays to sit on. The rest of the wires will be neatly bound up and set aside.
A friend luckily stopped by and gave me a hand stuffing the wires into the footwell. I was tugging on them lightly before he arrived, but it wasn't working well at all. With his help, we had the wires all pulled in within about 10 minutes. Here is how it sits now:
And the mess I have to sort out:
Saturday will be filled with grinding, scuffing, sorting, and all sorts of adjectives. I'm hoping to get the wires organized, and the parts prepped for paint. I may possibly even get primer down=) We will see.
Tah Tah for now
Tah Tah for now
