Kevin's 93' Ls400 AYEEEE
  • since I have not posted a rear shot of my car yet.
    Gas $$$! by KEV.E, on Flickr
    • sweet machine.
      I want a video rolling. is it loud?
      Instagram: dankasrz_s666
      • Originally posted by DannyE32 View Post
        sweet machine.
        actually I should try and make one soon. the exhaust is still very subtle because I opted to get large mufflers to keep the sound down. I can't remember if they are 24" inches long or 28". either way its not ear deafening and doesn't drone at all. Basically it sounds like a v8 that's mellow and not too throaty. I kind of wish it was louder though but this sounds classy
        • if you still have the cats you could take those off, It should make it a bit louder
          • Ordered my coilovers last week mate, cheers for posting those photos of the work you had to do
            Although i cant go as low as you over here in australia (Laws are so strict in victoria), this car is a mad inspiration, thanks for sharing. Love the lines of the ucf10/11, mines ucf20 haha lexus represent haha.
            How low can you go before you run into issues? i just dont want to have to take to my struts thats all.
            • Sweet build! I wish the wheels were a more subtle color though
              • Originally posted by axelillo_PR View Post
                Yeah but I still have to go through emissions. I'm thinking of getting an X pipe put in and taking out the middle cat and leaving the first 2 that come off the headers. Not sure yet I'm going to redo my exhaust setup fairly soon probably.
                Yeah well the under carriage of the car sits way lower than the body panels so that is an issue. My car doesn't look extremely low but the frame is 1.5 inches off the ground if not lower. Also I had the flanges cut out for the rear mufflers and the pipes are just welded together because they used to get caught on everything and it would make the exhaust tips crooked. I should really look into getting a skid plate made for the oil pan because that sits pretty low as well. The UCA issue is probably your biggest concern though, if it's knocking on the tower you're ride will be terrible.
                • Originally posted by E30LIFE View Post
                  Thanks, didn't choose the color although it's not as bad as I thought it would be, and since they were freshly coated before I got them, refinishing is not a top priority.
                  I have been practicing with my camera a bit and here's some photos from the other night. Recently discovered RAW images vs just shooting JPEGs and you really do get a lot more control over the image. Any critique or tips on photography are welcome, I'm just trying to improve.
                  Dusty by KEV.E, on Flickr
                  Practice by KEV.E, on Flickr
                  • How did I miss your car at StanceWars? I probably walked by it 10 times and never noticed it. This thing is dope though. Keep it up.
                    • Ah k cheers hoping to get some ok lows, only worry is the po po here are hot on it latley.
                      • more updates.. go and make a video or take more pics.. paint something idk
                        • Fitted the coil overs mines ucf20 so I'm not sure if that has something to do with it but I didnt have to chop into that bracket for the Uca's. Mind you she's not as low as yours mines 75mm at the lowest point, stupid Australian laws haha. But still I have no wheel gap so I'm happy :p. even on the 17" ls430 she's rockingnatm. Mad pics of your beast keep them coming man i check and re read your thread pretty much everyday to see how it's going, cars so baller
                          • i love it so much but am so very sad about the front fenders
                            4 Cars, 0 Cupholders
                            • Originally posted by Xtra Big Kahuna View Post
                              Yeah idk man I saw everycar there twice at least haha, there's not much to do so all I did was walk around and check out the cars.
                              haha the popo's be regulating too much out here.
                              Thanks man, would like to see your car. I'm sure you'd have to cut the towers if you went lower
                              ah yeah, makes me sad too man haha. I learned my lesson about being too hasty.
                              • Not much of an update, haven't done anything cool really. Shredded a piece of my harness again, what I need to do is extend it so that I can move it around more and try to tuck it higher. Or else I should get a piece of sheet metal and cover it. Drove it on the freeway one night, came home parked it, everything was normal. Went to drive it the next day suddenly my brakes are all crazy and feels like I'm trying to stop on ice. There was kind of a crunching feeling and the steering wheel would shake like crazy. I thought maybe my M.C was going bad or brake booster, and after researching a bit I found that it could possibly be the gasket between the two. However no fluid was dripping what so ever from the lines or M.C or gasket. Then I remembered when I bottomed out on the freeway and my ABS light came on for a second. 3-4 wires were shredded but not all the way through, but apparently my ABS was screwed up. So I fixed that and flushed out the old brake fluid and bled the brakes. However my front calipers were seized so I had to take those off the rotor and manually compress the pistons on them.
                                Here's a pic of my frame. While the car doesn't seem super low the frame sits lower than the body panels, and also for those referencing the wheel gap up front and rear, take into consideration I cut 2.5 - 3 inches of fender and qtr panel out to mount the flares. When Battle Version finally makes the front NRCA's I will remount the front flare lower but will most likely not touch the front coilovers. As of right now with -3ish camber front I can not go lower without rubbing on my current tire setup. And I happen to like the 40 series tires and being able to turn quietly haha.
                                Also repainted the calipers copper w/ metal flake, they were previously painted silver but it just looked kind of basic
