Got oil pressure today by removing the coil wire and fuel pump fuse. The noise got much quieter but didn't go away. Something else is wrong.
Pulled the valve cover as it kinda sounds like a broken rocker. Oil tubes were dropping oil as normal but now I could hear the sound was at the bottom of the engine.
I jack up the car and climb under.
Adam was here to help and was cranking to motor while I listened.
It sounds like its coming from the flywheel cover. Rightfully so, as the flywheel cover has a huge dent in it from me dropping the engine on it. Sure enough it dented that and the oil pan, causing the pan to hit the 6 cyl connecting rod every time it comes around.
Oil pan must come off and get the dent removed. I'm just going to hang the engine as it sits
And drop the front subframe.
@nicetounfriendyou
