Saving a Porsche. Vr6 Turbo power
  • yeah its all good. going to make a new exhaust and intake manifold to change some things up and then maybe paint
    If you're ordering custom adapters, call 775.530.2483 to make sure you are getting exactly what you want. Thanks
    follow on IG: eurotrashapparel
    • This is an awesome build. I'm a porsche nut.
      '09 Infiniti FX50
      Loaded + OEM Aero, GTspec bracing, K&N, custom HKS Hi-power rep mufflers, custom GTM Resonated Test Pipes, Uprev Osiris tune: 367AWHP/352 TQ, 13.6 @ 102 1/4
      06 SL500, 15 S550, 08 CL550, 10 C300
      • ok so i rebuilt the turbo and it smoked a bit which i knew was normal and everything seemed fine. now when i backed the car up on 3 different occasions i got a puff/cloud of white smoke. just puffs once. My drain hole is higher up on the pan but im wondering if anyone has seen an issue that if the oil reaches the drain height it would cause this. besides this everything seems normal and runs the same. i do have a undersized drain hose compared to hole on turbo since i had to make a weird drain flange to clear cold side housing. i added a restrictor since the turbo was backing up with oil before. i put it on the oil filter housing but someone mentioned it needed to be closer to turbo?
        • after fucking around rebuilding the turbo and have it going bad i wasn't sure if it was just seals so instead of wasting money and time i just ordered a complete CHRA. installed and no smoke. about fucking time
          • R A D .
            • i am still on stock head gasket but i'm redoing the air intake so i will be adding an intercooler. gonna try and run 14/15psi on stock set up. honestly at 7psi its pretty fucking fun
              other future plans
              - building some adjustable end links for M030 sway bars.
              - guards LSD
              - poly bushings for all control arms
              - bigger front brake set up
              - short shift kit
              • So much YES! Happy you finally get to enjoy driving it.
                • updates?
                  i despise my car, capital letters, and probably you.
                  IG doktor_b
                  • Not really. car runs great. just going back now and redoing stuff. i did get rid of those stupid stretched tires though, i dont know what i was thinking. a porsche isnt a hard parker
                    • gorgeous car thanks for sharing it here!
                      • This is a superb build. Loving it so much. Glad to see its running well and cant wait to see whats in store!
                        INSTAWHAT
                        Tumblr
                        Flickr
                        • Comment
                          • If you're ordering custom adapters, call 775.530.2483 to make sure you are getting exactly what you want. Thanks
                            • This thing is badass. Are you going to water by the bridge I know euro trash has had a lot to do with it before.
                              Follow me on instagram: @watsupitsdenny
                              check out my bagged GTO build
                              • Your car looks fantastic! Glad to see that you're enjoying it.
