60psi is crazy haha
Saving a Porsche. Vr6 Turbo power
New oem pump i bought took a shit. Got new one in and no boost. Had my maf to close to turbo and i think its cooked. Waiting on maf now and rerouting intake.
Also adding a bullet muffler to hopefully calm down the noise at idle.
If you're ordering custom adapters, call 775.530.2483 to make sure you are getting exactly what you want. Thanks
follow on IG: eurotrashapparel
yeah i'm pretty happy with it. i haven't heard it yet as i'm not going to drive without the maf anyway so hopefully its here tomorrow and i'll put it back together. h20 isn't an ideal shakedown run lolIf you're ordering custom adapters, call 775.530.2483 to make sure you are getting exactly what you want. Thanks
What kind of foam did you use to sculpt the spoiler? Caps look awesome, love the wheels and wheel finish.
What a cool car, the camo paint isn't my cuppa, but what a bad ass Porsche![COLOR=#ff0000]Lifetime Project[/COLOR]--- 1999 Mercedes C230 Kompressor, but converted to Turbo. Attempting to finish it up.
[COLOR=#ff0000]The Daily[/COLOR]---2011 C350 4matic[COLOR=#ff0000][/COLOR][COLOR=#ff0000][/COLOR][COLOR=#ff0000][/COLOR]
Did it react with the resin at all when you layed the fiber glass hair stuff over the foam?
I only ask because I want to try and make my own lip spoiler.. Trying to figure out what won't react with resin.[COLOR=#ff0000]Lifetime Project[/COLOR]--- 1999 Mercedes C230 Kompressor, but converted to Turbo. Attempting to finish it up.
Looking amazing=) Did you end up finishing that upper hatch spoiler?
Originally posted by Earl View PostLooking amazing=) Did you end up finishing that upper hatch spoiler?
Tried like crazy to get the car to H20 up to the point i didn't make my 600 mile drive until 11pm friday night in a van lol. Got to talk to Chris at C2 and he informs me that the car will buck and bog down if the fuel pressure isn't set right. i also acquired the information that to set an adjustable fuel reg you need to do it with the vacuum line off
Heat issue was pretty severe. got hot, blew steam out for a bit due to the air pockets and my faulty design. well that kicked off a complete redo of the cooling system last minute. the main hoses were pulled back out and rerouted at the height of the frame rails and lower than the top of the radiator. The flaw i see, besides that was i took the bung of the head that went to heater core and rerouted it back to lower rad hose in the crack pipe basically dumping the hottest water back with the coolest right before it re-enters the block. i had my buddy turn me down a little fitting tapped with npt threads ran a hose from there to a bung on top of the radiator and now it should remove the air automatically using an overflow bottle, which i didn't have before.
And if it all wasn't frustrating enough i hit a live wire on my brand new griffin rad and put a hole in a tube. had to pull that friday morning to get fixed
Last edited by bradp@adaptecspeedware; 09-30-2013, 08:46 PM.If you're ordering custom adapters, call 775.530.2483 to make sure you are getting exactly what you want. Thanks
