congrats...that's some serious rebuilt! great job!
A Sherman Schwartz story. (e28 content)
thanks, I really wish I could go deeper into the build but my pockets aren't that deep right now. I'm thinking of picking up a second engine this fall to do a full build but that's last on the long list of parts.Originally posted by xispaki View Postcongrats...that's some serious rebuilt! great job!
just finished another order of parts, keeping my fingers crossed that this will be the last of it that's needed to put the engine back in next weekend. 30 left days to go!
Awesome work!! This is exactly what I want to do! I was just going to suggest picking up a spare M30, but you were thinking the same. Maybe an M30 turbo build.?.?.?.
I'm going to pick up an E28 in the next few months, most likely a 528e as a project/daily. I have an E36 M3 for when I want to go fast. I would absolutely love to bag an E28 ($$$$), but I will likely settle on coilovers and a full suspension refresh like you did.
I'd say do it, these cars are surprising cheap to work on. I have maybe $1500 total in the car as of right now. I will be doing bags this summer once the car is roadworthy again and start looking at boost after that, of course that means I'll start spending some serious money.Originally posted by Vaders View PostAwesome work!! This is exactly what I want to do! I was just going to suggest picking up a spare M30, but you were thinking the same. Maybe an M30 turbo build.?.?.?.
I've wondered the same, their not that expensive to rebuild and spending money in the right places opens up a lot of opportunity for power. I do look forward to the progress that's about to come with the next round of parts and this summer with the bags and wheel hopefully going on.Originally posted by OpelWagenGT View PostIt's not too often that you see people bringing a motor back to life like this instead of replacing it. I can't wait to see what you're capable of using this dedication in the wheel, stance area.
-Aron
so I've been a bit busy spending time with the wife to keep her happy and having to take care of the house. Hope to get my ass back to finish the engine assembly this week and shooting for the goal of putting back in the car in 7 days. I did find a few things today though, first by starting off with degreasing the worn shift linkage and power steering pump that was the cause of one of my worst leaks on a high pressure line (new washer and banjo bolts getting ordered).
did pick up my new bushings to get rid of that 400k shifter slop, one for the actual shifter, one for the linkage, and one (no photo) that mounts to the trans that I'll do after it gets cleaned up.
the one on the linkage was easy to get out since it was worn, just a flat head to push it out.
getting in was a bit tricky since the new one was stiff, but a simple clamp did the trick
getting the plastic one out was PIA to get out but after a bit of work it came out
after that it was cake and snapped back together.
cant wait to get it back in the car to see what it feels like.
and more progress, which is always nice to see huge amounts. sorry a head of time for the poor quality photos as I didn't have the iphone around to take them today.
first of was the valves, just a cut to mate to the seat. It didn't need much at all aside from a clean surface. Its done buy having the valve rotating and putting against a spinning grinding stone
to show the difference (uncut on the left, recut on the right)
and a little off the top to offset the valve seating deeper
next was the cut the seats, getting the machine dialed in on the first one again only taking a little off for a clean seal.
just one small pass and it's looking good.
next was lapping, didn't get a photo of the actual process but here is a photo from online.
basically you put a dye on the head and a gritty compound on the valve and drop it in and rotate it back and forth, the end result should be no dye where the valve seats. Everything what looking good till I got to my dead cylinder and got this
see the dye left? turns out the worn out guides caused the valve to move creating the seat to be oval shaped instead of the perfect circle its suppose to be. So it wasn't a burn exhaust valve but just worn components that cause my loss of compression and gave the result of a burnt valve when I was diagnosing it.
Lucky though it wasnt too far gone that it could be salvaged by grinding away more.
no dye this time!
that being said the head could finally start being assembled, so first were fresh valve seals.
then the springs went back in
and finally the cam
tomorrow should be getting the rocker and rocker shafts in and I hope start the final assembly on the engine. The current goal is to get the engine back in the car by the weekend!
so progress? well didn't get my timing bits in and had to leave the shop early so the heads didn't get finished, plus my buddy decided since I was focusing on so many details that he must polish my heads so he started...
basically getting rid of all the casting marks and making it look pretty since I'm doing a lot of detail stuff under the hood this time.
I did have a little time so I decided to get the torch to attack those broken water pump bolts.
the method was going to be heating it up and using wax to get sucked down in the threads, but it turned out the heat was more than enough to back them all out... pretty nice to not have to work at it.
after that I threw the alternator and starter on, both will get replaced with cleaner ones down the road but I've been getting nickle and dime'd to death on shipping parts that its eating away at my funds.
I did get home to one package, not the timing stuff I needed but something to at least keep me busy tonight.
the garage is a mess and I couldn't find my clamps to wrap the manifolds, so instead I decided to put on the gold tape. This was a bit tricky because it is $2 a foot and I bought just enough to do the whole fire wall. decided to start on the flattest point first and work my way out.
now this stuff isn't like vinyl, doesn't stretch at all so I have to take my time to make it the best I could. I will say next time the engine is out I'll do it all over but with everything off the firewall. I did have a fellow rival house member stop by and snap a photo...
I will say I need to take advantage next time the car is moved out and give it a good clean.
I did get it all done minus the panel that covers the wiper and blower motors, I have to take it and bead blast it to get it clean enough. I'm about 99% happy with it.
also had a little time and threw on the coil
Looks like I'm staying on schedule and hope to be driving the car next week if everything works out right. 25 days till its suppose to be ready for his first show!
good progress tonight!
first off I got a set of these....
test fitting them tomorrow, but not dead set of actually rocking them since they detour away from the original plan.
also snagged a new air filer, need to make a new bracket for everything though so the maf doesn't damaged the valve cover.
figured if it was good enough for a f40 or topless integera then its good enough for sherman
anyways installed the new timing guides that came in yesterday, pretty straight forward
got the intake rockers installed the other day, so it was time to finish them off
and after picking up some dry ice and shrinking the shafts is was a breeze to get them in
all done! nice know that I have a rebuilt head that should be good for another 400k
had to adjust valve lashing since its much easier IMO like this. I've done this so many times now that I can finally do it by feel
knocked out the head install, timing chain and water pump with a quickness
lower cover and and starting to look better
and holy hell it looks like and engine again!
I have decided the maf and alternator are going to bother me, so they will get cleaned and painted next time I'm working on it. I'm starting to get behind and plan on now trying to get the engine and trans in next weekend, it's trying to find this fine line of rushing to get it done but paying attention to details.Last edited by budski; 03-23-2012, 12:26 AM.
Looking good man, what size are those gotti's? I actually just grabbed a set of cheap gotti reps (15x7 et 0) temporary fix just to get off the bottle caps lol
nice, looking forward to updates!91 DiamondSchwartzMetallic S52 Slicktop, 91 Calypso M42, 89 Royalblau M20, 84 Euro E30, M535, Euro e24, ap1
www.RenownUSA.com
ig @rudestance / @renownusa
17x9.5, they need a lot of work to get to fit at least a 2" spacer.Originally posted by E28stoff View PostLooking good man, what size are those gotti's? I actually just grabbed a set of cheap gotti reps (15x7 et 0) temporary fix just to get off the bottle caps lol
BUT, did get some 225/45 mounted.
the front was hitting the strut before I could even get the lug bolts to thread, rears were not as bad but still what hitting the strut.
good chance I'll just set them aside till I get the bags on and see where I'm at before orderings spacers, so it will be 16's for a while which I picked up cheap tires tonight.
for now I'm waiting on rocker shaft plugs and a day open to haul the car back to the shop to put on the lift.
got around and go the header wrap put on. Also got the vacuum lines this time tucking them in so its more of a accent vs ricer-istic, along with coolant lines and painted the air vain.
Thurs I hope to get the alt and PS pump done along with making brackets for the air filter/air vane.
