more work today.
finally got the heads off, found the walls still have its cross hatching which is awesome but I did see the pistons kissed the intake valves, Good news is that the valves were just fine but I need to chase down my why it happened.
bottom felt nice and tight
block is looking pretty nasty though, but with the bottom end all tight there is no reason to hot tank it.
dropped the cam out
then removed the rocker shaft (huge PIA)
not only was is a difficult to get the shafts out I managed break a rocker, got one on order already. Needless to say if this is the worst them I'm OK with that.
getting the valves out was a breeze.
and gave them a good clean with a wire wheel, a lot of carbon on these
check the head to make sure it was not warped, which it was well in spec but decided to take .005 off for a clean surface and cheat a little for compression.
so much better!
started prepping to cut new seats and discovered the valve guides on the exhaust side were out of spec so those were also ordered and the heads are on hold. That being said it was time to get after a few cosmetic things...
much better, but still needs paint to keep that silver
after a quick spray.
scrubbed the block and gave it some black, started to put some parts back on.
now while I'm waiting for parts I'll attack the car next getting it torn down.
dropped the cam out
so much better!
