Alright got some more work done. Got the driver's seat fully mounted and done and I'm about halfway through with getting the passenger's side done.
Beware, these mounts might look ugly to some of you. I basically had to weld three separate pieces together for each corner. I started off by welding a flat plate on the floorpan (roughly 2"x2") as reinforcement for the rest of the mount. I then took a piece of the 1" square tubing and mounted it to the slider and mocked it up and then made whatever was necessary to fit between the bottom plate and top mount. Hope that makes sense, it basically came out like this:
And now I have a new driver seat! Here is a picture of it all mounted up and ready to go. The second picture is it popped up and forward to allow passengers in the back:
Then I pretty much duplicated the same design for the passenger seat. This seat will require a slightly different approach to allow the "slider stopper" or whatever it's called to work:
