7mgte 2wd hilux swap (its gonna take a while)
the welds a strong. had the welder. its a 200 amp welder and I jacked it all the way up with .9mm wire. whole end was glowing by the time it was done. I did raise the motor but then by bonnet wouldn't shut. brought the engine forward and then the radiator wouldn't fit. I have a spare front sump. ill maybe modify it later and swap it out when the clutch goes.
So everything was going awesome. did some sick skids. then I hit full lock once and bent the plate welded to the drag link. bent it back but it slowly got worse. so I decided to modify the sump but pickup was under the drag link. turned out that the mid sump actually clears everything perfectly on the 2WD. apparently its just the IFS 4WD models which require front sump. so changed the sump for a spare mid sump I had. By far the messiest job I have done on a car. being underneath it with oil dripping everywhere was horrible. but now everything clears fine. got a new drag link lined up so will throw that in later. for now just waiting for the sealant to dry.
will post a vid of some skids soon
I have been tackling another grinder-eye incident and a problem with stalling at 3000rpm. Fuel pump wasn't cutting it so I used the lift/primer pump, and high pressure pump from a VL commodore. Works mad good now.
Unfortunately it's still really loud so I don't take it out much. Also my old work closed down so money has been tight. Working on adding another muffler to the mix to quieten things down, but I think my exhaust gasket is leaking, and causing some horrible noise. If aussie laws weren't so tight, I'd run strait pipes. Already putting together the GTE engine. will hopefully rebuild the turbo soon, but thinking about going T04 route. Regardless 200 galloping ponies from the N/A is a wonderful improvement on the 22R. Will try get my brother to record some skids. Shitty video of it driving just for proof its not dead. Sorry for the loud music I was trying to drown out the exhaust.
Got a short shitty vid of it going up a hill near my house. sorry for the camera work. I have no power steering, I was approaching a school zone and went through a round about near the start. I wish I could keep it sounding like this but the po-po will have my ass in no time if it stays this way
I know I haven't posted in a long time but oh well. not much to update. car has been running like a dream. took it to a buck and spinster night yesterday. did awesome skids, is crazy fun to whip around. had 2 cops look for any problems, and they didn't even notice the different engine. on the way home got yellowed again for bald FRONT tires. im ever so saddened.
