1991 Mini - Project Trig
  • #61
    Good work Andy.
    I'll be up soon!
    • #62
      love build! keep up the work!
      • #63
        Originally posted by Minuki View Post
        Good work Andy.
        I'll be up soon!
        Will have plenty for you to do!
        Thanks! Trying to ue up the small amount of free time I have in the garage...
        • #64
          Another day another bit of progress!
          Went out tonight to see what was needing done next. Thought I would try and tidy up the front subframe as its not too bad but the time it was going to take me I think its just going to be best to get it blasted.
          So with that done I routed the loom through the bulkhead blanking plate that had dried off overnight (in silver to contrast with the red. The standard black looks crap)
          Then I routed it throughout the car ready for attaching to everything. Kinda simple when its all labeled up!
          Going to take the frame to get blasted by PPS tomorrow. They haven't returned my calls to book it in so going to doorstep them instead! Hopefully they will be able to get something done with it asap.
          Next stage for me is to get lighting stuff located which involves adapting the holding rings to fit the MK2 Golf crosshairs. So still lots to be getting on with!
          • #65
            Wow, killing it. Love it man. Good work!
            • #66
              Thanks man! Good to see its seen as good work by someone with as high standards as yourself! Loving your latest BM. So classy and clean.
              • #67
                No progress so far today (might get out to work on it tonight) but I ordered a load of bits from MiniSpares today. Took advantage of my TMF+ membership and got a nice 7.5% off the whole lot Totally worth the £5 to get the membership! Still came to a fair whack all added up but everything is needed to progress.
                Also after weeks of thinking about my subframe and what to coat it in I phoned PPS today and Ive decided to put it to them to get blasted and coated in high gloss black powder coat. The way I see it is that the car won't be doing loads of miles and will be getting regular cleaning. Im thinking of putting some clear laminex on the bottom of it where it faces the road to prevent stone chips as much as I can. The laminex is clear so won't be noticeable and works great on car front ends so why not a frame!
                Dropped it off this afternoon and should have it back in just over a week. Means a delay on assembling the frame but hopefully my parts will arrive quickly as they are coming by courier.
                I also ordered some Scooter deck grip tape. Answers on a postcard for the uses of this......
                I got more done to the car tonight though! Not much but what I was doing is complicated....
                As you will probably know already I have MK2 Golf crosshair headlights to fit. The problem with these are they are ever so slightly too large for the inner mini headlamp rings. So I had to modify these rings to fit!
                Heres the light in question....
                and here is the cut to stretch the ring out to fit the glass.
                I didn't get a chance to get the placement/orientation done tonight but I did have a quick mockup on the car. Im beyond happy with their look!
                Something so subtle but you can guarantee I will be the only Mini on the show field sporting them which is great.
                • #68
                  Grabbed another evening in the garage tonight.
                  Went out to get the headlight fitted all perfectly but got annoyed with it so will leave it to another night :lol:
                  I did get the headlamp bowl fitted though and the rivets have a strong hold.
                  Not sure if the rivets were standard or not but the old ones were held in by them and they were solid so new ones replace them!
                  Then I located my internal bonnet release and fixed the bracket supplied in the kit to the lower dash rail. Replaced the kit bolts with stainless as shiny looks better than matt black in a bay.
                  I got a few little bits like more wiring and fuse box located etc etc but no pics as its nothing significant.
                  I also got my door striker plates fitted after their fresh paint job. They will eventually end up stainless steel but Im trying to reign in the spending at the mo just to get this back on the road.
                  I also marked out where I need to drill holes for the harness bar to go. Used my iPhone as a spirit level and it is more sensitive than my actual level......
                  The bar itself has some weird looking welds so Im smoothing them off by a bit of careful grinding and then adding filler on top. This will make it look like one piece of metal once smoothed and painted. lovely!
                  and I did my usual end of shift thing of marking down another day on the calendar. Ive got 66 days until the Thistle Run. I want it back on the road before mid May to iron out any niggles Im bound to have but we shall see how I get on
                  Should get more done over the weekend as Im working all day and home mid evening which means no time for uni work :lol:
                  • #69
                    Yet another day, yet another parcel!
                    MiniSpares order arrived half an hour ago. Really impressed with their service as always. Specified delivery between 16.27-17.27 (hows that for accurate timing!) and it arrived on time. Perfect!
                    So onto the pics...
                    The order breakdown is above this post anyway so won't go into details
                    Mainly fixings etc. Two chunky bags are the ball joints. them have arrived assembled but need taken apart to lap them in as they are a bit rough inside. Easy to do though with the aid of my drill
                    Brake pipes are a cooper/nickel mix (commonly known as Kunifer) which is easy to bend by hand and harder to kink. Making it super easy to install! (he says hopefully....)
                    They come pre fitted with all the end fixings and labelled with a guide to where each one goes. Much easier and way less labour intensive than making your own!
                    And something i didn't expect was this. Set of plastic clips to attach it all to the car underbody
                    I also got loads of nipples ( ) for radius arms, wheel hubs etc etc to keep everything greased up easily!
                    Should get the battery cable and a couple other bits fitted tonight
                    • #70
                      Nothing like getting parcels I think my bro used to use the same crowd, never a bad thing from him about them.
                      • #71
                        Well tonight I got some more done with help from my mate Greig.
                        Got the battery cable installed but no pics as its under the car and its dark under there....
                        Ive decided to put the engine in from below, along with the subframe, seeing as the car is in the air anyway. This meant we could get the brake servo in without blocking the path of the engine. Win!
                        So put Greig to work on that...
                        and then we thought what to try next and decided to do the lights. Two pairs of hands are definitely better than one and we managed. Needs fine tuning when its all back down on the ground on a flat surface but they fit! Just need to mod the outer rings a bit to fit over the now larger inner rings.
                        So more progress as ever. Running out of things to do when I have no subframes but hopefully PPS will have the front one done by the end of the week so I can get torn into it over the weekend depending on my workload.
                        Thanks to Greig for the helpage!
                        • #72
                          So I haven't progressed too much with everything over the last couple nights. Lights are continuing to be a pain but determined to get them done.
                          Only pic of progress to show that Ive got is I managed to get the grip tape fitted to the pedals. Looks ace and hopefully will make gripping them much better.
                          Before/after photo....
                          and both done
                          Notice the height of the brake pedal. Way higher than the clutch and the throttle pedal is even lower than the clutch. Sounds weird but it makes heal and toe far easier. You only do it under braking and as a result your foot is at the perfect height to roll onto the throttle instead of up and onto it in many modern cars.
                          Hopefully PPS will phone soon saying the subframes completed and I can get it all reassembled, engine on and then installed in the car.
                          • #73
                            WOW! this car is amazing i love the red color you did, an so much detail!!!
                            • #74
                              always like seeing progress ! cant wait to see the final product
                              C280 Build Thread
                              C43 ///AMG Build Thread
                              E320 Wagon Build Thread
                              Follow me on Instagram:@SD_210
                              • #75
                                Thanks man! Comments like that keep my motivation up!
                                Thanks! Not far off now....
