E30 Touring resto - Pic heavy
  • #76
    Small up date...
    I've a few stuborn rust spot that needs a bit more gel, going to treat all bare metal again also (until I'm ready to primer it). Need to make up a bracket for the airbox and abs bump. Some how need to get those welds around the strut ground down, angle grinder cant get at them and the dremmel grinding stones I have are rubbish :
    The underside needs a little bit of attention here and there but mostly it needs a good clean, rub down for a 2nd coat of primer and I can then underseal and stonechip it all :
    • #77
      Spent a bit of time last night making up a card template for the airbox bracket, happy with it I transfered it to steel this afternoon. Many hrs later and a timber mould to help with the edges and one airbox bracket. I just have to figure out a way to transfer it to the red shell so it's in the exact same position :
      • #78
        Took awhile but
        Got some more other pics I'll upload over the next week or so when I get time.
        • #79
          Looks like this is heading in the right direction to be a pretty sick car, keep it up.
          • #80
            Back on the ground , can't wait to see more.
            • #81
              Thanks
              is right
              Time for a proper update, not had much chance over the last 2-3 weeks to post up pics of progres.
              2nd coat of primer
              Underseal and then a coat of paint
              I'm not to happy with the underseal I got (aerosol from BMW, great for touch-ups though1) so the painter is going to be sealing it up again while he has it.
              I had a few of these bits painted with hammerite hammer finish paint, it didn't match the subframes so I cleaned them back again, etch primed and paitned them last week.
              All the chassis and suspension parts to go on to get the shell rolling again.
              A moment of scratching heads trying to figure out how to get her down of the spit :
              15mins later :dance:
              And finally this morning
              Of for paint she went :dance: I won't see her back for another 10 weeks now but I'm very confident when she's back it will have been worth the wait.
              A thread should appear on autostadt's forum with pics from Marty as work progresses, I'll copy everything across as/when they get posted :dance:
              • #82
                damn, 10 weeks that must SUCK
                Floccinaucinihilipilification
                • #83
                  Yes and no. Whats 10 weeks when I've been at it for 18months now? But I'd love it back sooner so I can drive it sooner as it will be close to winter and I don't think it will be driven then. He talked me through his process and he leaves the primer and fillers settle for a week or so before another rub down and more primer, leaves it settle again, same with paint and clear so there's a few weeks straight away where he won't touch it to let all settle.
                  ---edit---
                  He will be lead loading before filler where ever required, so not just fillers which I think was part the reason for choosing him to paint it.
                  • #84
                    10 weeks is a pretty long wait but as long as it's been done right you'll stil have years of driving fun.
                    • #85
                      Pretty confident it will be done right and that I can enjoy it for many more years! He seems like a very thorough guy and has a good rep.
                      • #86
                        Why dont you cleaned the engin bay ?
                        • #87
                          I will be (with the painter) trying to neaten things up a little bit and I intend to re-route some of the wiring to make it all look a little tidier. I thought about smoothing things out but I'm not a fan of it for this project, maybe another time. All will look fairly stock but a little cleaner.
                          • #88
                            Finally got the lend of a engine hoist this week and started by pulling the engine from the old shell
                            Nothing could just be straight forward with this build : The oil filter cap refused to come of, after trying a few different things I eventually wrung the hex nut and proceeded to remove the cap with a little more violence :laughing:
                            If anyone has one spare, I'll take it of your hands.
                            Engine is now back on the stand and I think I'll spend some time cleaning it now and just hope she runs when it all goes in the car.
                            • #89
                              any updates on this? dying to see how this turns out
                              --Golden Boy E30 Build--
                              --Etsy Shop--
                              --@ayyyitsmikey--
                              • #90
                                Progress has been slow the past month because of a few RL things (and maybe lazyness?).
                                I've neeb slowly building up the few engine bits I removed and giving them a clean, hada bit of trouble late last week that didn't just end with me struggling to remove a stuck/broken bolt. Having some problem with the engine, I was turning it over by hand when it suddenly stopped, turning it the other I can got about 180deg and it also stops. Thinking maybe that the chain skipped a tooth, not really sure. I've been away since Sunday and it happen late on sat so not really had much time to look into it.
                                Paint-wise, I spoke to him 2 weeks ago and he had started on prepping the bumpers and cills etc, he was to start on the body this week. I'm probably going to head down to him next week at some point to see how he's getting on.
