Volvo 242 Turbo, 16v turbo, widebody, Rota wheels++
  • almost finished welding the manifold now :P
    the engine block is at a machine shop right now, they are boring out the sylinders and putting in Ductile iron sleeves custom orderd from L.A. sleeves!
    And the 16v head is also at a shop :P long story short: 3 angle valve seats, bronze valve guide`s, stock valves, porting of intake and exhoust, match porting inntake manifold to the head ports ++ head will easly do the 750 hp im aiming for!
    - volvo 242 low and wide Project
    - Audi v8 4,2 twin turbo
    - Honda cbr 900rr (1200cc++)
    -Audi A8 W12 6.0 daily driver
    • so, since the 740 rear axle is wider then the 240, I dont need spaceres anymore
      redrilled the bolt pattern, so now i can just move the bolts between 5*108 and 5*114,3!
      since a lot of my engine parts is out, i have just been tinkering a little here and there :P
      Front bumper mod step 2 :P
      this bumper will only be used as a mold, bumper will be cast in Carbon fiber!
      Along with the rear bumper, dashboard and a few other parts
      • so, time for a few new pics :P
        Made a Paint booth in Our garage
        • mounted the front suspension, With all the goodies
          coilovers adjustable between 80 - 170 mm lower then Stock :P
          and working to finish the custom rear axle! 10cm wider the the 240 axle, and adjustable coilovers (same ish as the front)
          • I've never noticed this build before. Amazing craftsmanship, following this for sure.
            • Looking good man! Are you keeping the rotas?
              R.I.P P.WALKER 2013/11/30
              • Originally posted by 244Brick View Post
                yes, i know many out there dont like the rota`s, but i like the look on these!
                but im also going to get some 16 inch Steelies for track use to :P cant play around on the track With tires in this price range :P
                • That color.
                  Sup. Call me Z.
                  My Accord "build".
                  • this color?
                    • Body color is great.
                      Volvo Build Thread
                      Bmw Build Thread
                      Toyota Build Thread
                      zanebonk instagram
                      Tumblrrrr
                      • lifted the engine Block and gear inn today, and cut out a hole for the shifter! and starting making the rear gearbox mount tomorrow!
                        • Originally posted by volvo242 View Post
                          this color?
                          Damnn that color scheme is perfect !
                          I'd love to know the paint code of the body
                          • home made carbon dash
                            • btw, also built a widebody Benz for a friend, tok me about 1,5 month to do all the metal work! yes, its all metal, no fiberglass :P
                              All hand built in 0,9mm steel plate. 2 layers in the rear wheelhouses and 1 layer in the front fenders. + rolled lipp so it wont cut the tires and for strength.
                              • Speechless at the moment...
