E30 "Mad tyte jdm" 1JZ-GTE build
  • Final specs are 16x9.5 on all four corners, 26mm spacers in the front 38mm offset wheels, 35mm spacers rear 38 offset wheels.
    1984 BMW 318i- 1JZ-GTE
    • Well over the last few days Mike and myself have been working on his exhaust. It is a fully 3" equivalent ovalized tube exhaust, v-band clamps, etc.
      We just tacked it together, and Mike is dropping it off tomorrow to have it tigged.
      Time for some pics!
      And some badass pie-cut work.
      Originally posted by Kielan
      • got my exhaust back all nicely tigged..
        clearance is much more gooder
        just have to make the axle back section now
        • Looking awesome so far!
          If you don't mind posting the dimensions on that steel tube you used to make the lower rad support I would appreciate it. I want to do something very similar seeing as my skid plate currently mounts to the paper thin oem rad support and is doing a good job crushing it.
          • Originally posted by chrisbmx68 View Post
            I'm not 100% sure off of the top of my head, but I think it was 1 3/4" x 3" with 3/16" wall thickness. I just went to the local steel supply and had a look at their cut peices, and grabbed what would work. hope this helps.
            • Aw man, I know that fucking feeling. Best of luck with the rebuild man!
              E30 V8 Build thread
              Go here be happy!
              Instagram: stuartrussell
              • Awsome build ! can't wait to see that thing running low
                • thanks for the info I thought it looked about like a 2x3 and the smaller pieces I assume you plug welded after inserting them into the upright portions?
                  Really sucks about the rebuild good luck getting it going again it will be awesome!
                    yep that's what I did..good luck!
                    • here is my other project that's keeping me busy
                      it's a 1976 yamaha xs500 that I turned into a sort of ratty bobber/ cafe bike
                      • I want to build a cafe racer so badly it hurts. This looks great man. The whole build thread is a great read. I can't wait to see what comes out of the whole rebuild now
                        • Whose piece of shit silver workbench is that?
                          • Originally posted by HooWybrow View Post
                            get working on it!
                            • Thanks for the tip on the tube size, did it slightly differently than you, turned out pretty decent. Could have used a slightly thinner wall but itl do.
                              • Good stuff man, keep up the good work.
                                1991 E30 Sedan - Build Thread
