E30 vert driftcar build...Motor swap, gussets, japanese crap, and overall stupidity
  • #76
    Not sure where you plan on running IC piping but you may wanna cut the holes for it pre-paint. I ran mine right behind the headlights going down through holes I cut on the flat part in front of the inner fender. Maybe you have different plans, but figured I'd give you a heads up
    • #77
      Intercooler is gonna be in the engine bay.
      • #78
        stoked to see more bmw's drifting.
        mine is undergoing the same process with the exception of a few parts.
        did you go with a 1pc driveshaft?
        • #79
          ah ok makes sense then.
          • #80
            Awesome! I dig the whole thing so far. Only thing I don't get is the speed hole design of the A pillars... any particular reason why that is better than just the tubes you'd normally have there? I've seen the speed hole design a lot though. If nothing else it looks cool
            • #81
              yes
              • #82
                Not sure yet, waiting until the motor/trans are in to make the measurements and decision.
                There's still a tube there like a normal cage. The thing you're talking about is a gusset, basically a metal plate that's welded to connect the cage to the frame of the car for added rigidity. The plates are then dimple died (the holes) to strengthen them.
                • #83
                  Nice! Where is this shop you guys are all talking about? I'm in the NW burbs. Is there a good place to get some local event info too?
                  • #84
                    Touge Factory / TF Works in Elk Grove, IL is helping with the fab work on the build, and IND Distribution / A&L Autobody in Palatine, IL is doing the body work.
                    For local drift event info you can check out:
                    • #85
                      Good lookin out. Maybe I'll see you at an event.
                      • #86
                        I've seen that steering wheel countless times, yet i can't recall it's name lol someone help me? i like
                        awesome build btw, although i am wondering why is everyone going crazy with SR20's? i've counted about 5 BMW's (including yours) today that have an SR20 in them, the sound is distinctive. Why not a S42?
                        “ Driving down the road becomes a masterfully balanced ballet of dodging, looking ahead, and saying “oh shit.” "
                        - Mike Burroughs, Stanceworks
                        • #87
                          It's a momo benetton wheel. As for the SR, I had one laying around, its dirt cheap, it makes more than enough power in stock form, and more power is easily attainable, 4 cylinder gives better weight distribution, its cooler than an s54, no oil pan scraping issues, etc. I would have gone S14 or F20c if cost was no option, but having the SR laying around made it a no brainer.
                          As for the car, there's been a lot of work going on, but not much to show for it just yet.
                          In lieu of a decent update, went out and screwed around in a buddy's little parking lot this weekend with my beater, haha... Here's a little video.
                          • #88
                            schweet e30 id never even imagine a cab drift missile
                            • #89
                              wow that engine is looking fine. can't wait to see more.
                              • #90
                                Not a ton of progress for how long the car has been sitting, but the car is finally out of the body shop... Swap time.
