Step them up to 18"
Aussie wheel tech/discussions
keen as long as its not going to bust my walletOriginally posted by Craig Winters View PostI'm feeling like doing something different. Maybe a copper lip. Mirror or brushed finish . Who wants to try?
Got some RS and simmons waiting for some whitehorse love once the bank account says okSarcasm is easily calculated on vortex dude. Take 4 parts GLI lip and divide by BBS RS. If you are left with a remainder, subtract it from omgmoarlow. Profit.
Thanks for the pics! Not the shape I'm after, however once I do some measuring I might be way off with what I'm needing. I'm planning on sandwich mounting mine, same as you did, and might end up keeping with my 1in fronts and then your 1.5in rears(if you're not using them) might just work, in which case this shape lip would be good. I could be way off wanting 3in rears!!
Are you sure they're only 1.5's....they look deeper, more like 2in, but that angled bead edge might be what's throwing me off? I need to get the wheels back(tomorrow) and do some mocking up(this weekend), then I'll know what sizes I'll be needing. But I know for sure I'll need much smaller barrels, lips I'm not positive on yet.
Speaking of which, Craig, how much do you charge for barrels, I might be needing anything from 4in, 4.5in or 5in(most likely 4.5in)? Again, I'll know more once I do a mock up.
I'll let you know how I go with my mock up......I'm hoping I can go deeper, but if not and you want to sell those I might be interested. Can you measure the overall width of them, from under the bolt lip to the top of the bead lip just to confirm they're width?
Slightly OT, but can anyone explain the difference between flat back vs non-flat back BBS wheels (and its significance)?
Also, where do you guys purchase your lips and barrels from?
I'm a noob that is looking to purchase and build a set of 17 inch BBS RS and am interested in doing some cost analysis type research to work out what costsI'll be faced with if I were to completely rebuild/resize a set.Last edited by datzed; 05-27-2015, 10:36 PM.
Flat back is just that, completely flat across the back pad of the wheel. The other type is raised around the holes, almost like a raised flower(that's how I describe it anyway). Flat backs can be redrilled to almost any PCD, non flat backs can only be offset drilled and inserted to a close PCD to what already exists.
I have used a few, but for my last set of generic lips I went with iclair.de, don't use conceptwheels.be(rubbish!!!), and I've heard Felgen Fuchs are good too.
Prepare to spend big $$$ if you plan to do a quality rebuild from scratch, especially if you refurb and/or go new with every part. Resizing, even more again.
Ah thanks for the info.Originally posted by Beware View PostFlat back is just that, completely flat across the back pad of the wheel. The other type is raised around the holes, almost like a raised flower(that's how I describe it anyway). Flat backs can be redrilled to almost any PCD, non flat backs can only be offset drilled and inserted to a close PCD to what already exists.
Can RS's be rear or front mounted without any issues?
Also, are slant lips the only way to extend the size of a wheel beyond 1inch (i.e. from a 15inch to an 17inch)?Last edited by datzed; 05-27-2015, 11:38 PM.
Rear mounted, no, front mounted, yes, but you should have them machined to suit.
As far as I know, slants are the only way to upsize anything(face size depending though I guess), unless the wheel comes in a flat lip situation(ie Modena's as per above, the 16in flat lip uses the same size centre as the 17in step lip, so the upsize doesn't require a slant), then a step lip can be used to upsize. I hope that makes sense.....Craig from Whitehorse can probably tell you what you need to know for sure though as that's his business.
A 15-17in upsize would look a bit whack IMO.....1in upsize is usually ok, but 2in can get the proportions looking really weird, but that's just my opinion.
