Magnets, how do they work?
How does this work
 because going around a corner and seeing your sidewalls smoking makes you feel like a god damned sexual tyrannosaurusOriginally posted by Dr.AK View PostAm I the only one on here who actually thinks rubbing like that is pretty retarded? You can achieve amazingly tight fitment without rubbing, so why do things halfway?
 PavelOriginally posted by Kielan View PostWith crazy rates yeah... But I don't think anyone with a reasonable thought to their mind wouldn't go crazy with that..
 Self clearance YEAHFUCKYEAH.GIFOriginally posted by padraigmk3 View Posti drive with the fender on the tire sidewall. things just eventually wear away until they fit they way you want them to.
 this guy.......... is onto somethingOriginally posted by padraigmk3 View Postbecause going around a corner and seeing your sidewalls smoking makes you feel like a god damned sexual tyrannosauruscars and stuff
 from that video his spring rates are not as high as i would have expected them to be. Mine are 18k/16k and my wheel moves no where near that much. and my wheel to fender looks identical in the rear
 My main "how did he do that" question is the front fenders. How does he turn the wheel and not rip the fender off? If i tucked my tire that much there is nothing that would allow me to turn in and not hit the fender. PS lifts the car a little bit, but nowhere near enough. Its the only reason why i have considered moving to the dreaded air setup. i need my frame lowersigpic
 1990 Nissan fairlady Z32 - long term build
 1982 euro porsche 930 turbo
 "A less- assuming enthusiast probably wouldnt even think that this Z ran because of how naked the engine compartment was. The motor looks as if it just floats there, with nothing else in sight." Super Street 9/2012
 http://www.stanceworks.com/forums/sh...ad.php?t=19185
 I am willing to bet thats exactly what it does. The PS lifts the car up just enough so that it rubs... but doesnt destroy the fender. Thats how my M3 was.Originally posted by 1badg35 View Postfrom that video his spring rates are not as high as i would have expected them to be. Mine are 18k/16k and my wheel moves no where near that much. and my wheel to fender looks identical in the rear
 My main "how did he do that" question is the front fenders. How does he turn the wheel and not rip the fender off? If i tucked my tire that much there is nothing that would allow me to turn in and not hit the fender. PS lifts the car a little bit, but nowhere near enough. Its the only reason why i have considered moving to the dreaded air setup. i need my frame lowerLast edited by skrapez; 12-23-2011, 08:33 AM.cars and stuff
 Originally posted by Kielan View PostStiff coilovers, and I'm betting it cambers in just enough. OR he is bottomed out and there is no travel and then he has no issues.Originally posted by Jozi View PostI suppose I guessed that might be the case. Prob not very suitable or comfy on Irish roads, never mind the damage it could inflict.Originally posted by Kielan View PostStiff rates won't inflict damage...
 It's not.Originally posted by Oxer View PostIt could to the strut tops....The strut towers will crack over time if you drive long enough. This picture is not even with "crazy" spring rates.Originally posted by Kielan View PostWith crazy rates yeah... But I don't think anyone with a reasonable thought to their mind wouldn't go crazy with that..
 That's why you add reinforcement plates, in form of a strut brace or something alike. (im running around 16.2kg/mm springs. and in the front i have a strut brace and in the rear i got some reinforcement plates that are standard on the Z3.)
 Whats this PS, you are talking about?Originally posted by skrapez View PostI am willing to bet thats exactly what it does. The PS lifts the car up just enough so that it rubs... but doesnt destroy the fender. Thats how my M3 was.
 I know the more caster you have. the more camber will be added when you turn also it will lift the car a little. That's why i'm planing on getting the ///M3 97+ front knuckles also the offset front bushings for added casters, it would go great with my front caster/camber plate.- Instagram@jdjurhuus Instagram@jdjurhuus
  Stretchsaurus and Pokemon. Stretchsaurus and Pokemon.
 The e30 won't be nearly as easy to get it sitting like that. Getting bmws stiff in the rear is tougher than a lot of japanese cars. They also don't camber in as much naturally. The more camber you have the more it will move inwards on compression as well.
 Example:
 compressed
 lowered and compressed, no actual camber adjustment
 IG: @_olliee
 What about FMU gold wheels? the rear shocks came up through the shock towers it tore the tower apart.Originally posted by Jesus Christ View Postas josh has stated the PS lifts the car just enough to rub and not grenade the fender.
 cracking strut towers happens on track cars, you will get struck by lightning twice before you crack a strut tower with under 17K springs in a DD.
 Also i think if i remember correctly that Sean's M3 stated that his front towers started to crack in the front. This was about 1 or 2 years ago.
 And i ask again, what is this PS you are talking about? Is it power steering if so the statement is wrong.
 Its the Caster that will lift the car also will it add more camber when you are turning witch will help when you are trying to get a tight fitment. Caster plays a big role in not rubbing when turning.
 Older cars with out power steering will also lift but not as much because they have less caster. this is because caster makes the car heavier to turn and older cars this was not wanted. But with the addition of power steering the engineers were able to add more caster and the car would still be lighter to turn. they added caster to increase stability in a straight line when going faster.Last edited by Zic; 12-23-2011, 02:40 PM.- Instagram@jdjurhuus Instagram@jdjurhuus
 Zic is right. Its the caster, PS just helps make it easy hahaOriginally posted by Jesus Christ View Postas josh has stated the PS lifts the car just enough to rub and not grenade the fender.
 Also Ive cracked quite a few strut towers with much less than 17kg spring rates. Imo the street is harsher on strut towers than the track just as youre much more likely to damage a wheel on the street than the track
 IG: @_olliee
