tired of coils
yeah you still need bags...aerosports for the fronts and then you have a few options for the rears, if its like the E46 it seemed like my jetta back there, like anonymous said you just need some brackets for those
that price is cheap for a manual kitMy super boring build http://www.stanceworks.com/forums/sh...other-M3-buildInsta Mintyhinrichs
That kit is SOOOOO bare bones, never really liked it ever since it came out. A 5 gallon tank with a single 380 compressor will take forever to fill. I personally think you're better off piecing together your own setup and after it's all said and done, that will probably cost around the same or less for everything and have better components
Don't even waste your money on some choncy ass kit like that! Paddle valves... No thank you. Spand a couple extra hundred dollars and do it right the first time. I know ts quite a bit more, but this is the system I am running ->Digital<- but you can do something in between for an in between price.
do u have any pics of your setup?Originally posted by LuckyBoyOne3 View PostDon't even waste your money on some choncy ass kit like that! Paddle valves... No thank you. Spand a couple extra hundred dollars and do it right the first time. I know ts quite a bit more, but this is the system I am running ->Digital<- but you can do something in between for an in between price.-Jorge-
Is it your daily?? you might want to consider some sort of management like eLevel or AutoPilotsigpic
SteveO@OpenRoadTuning.com
(888) 407-2997
>>>OPENROADTUNING<<<
>> CHECK OUT OUR NEW WEB STORE!! <<
Become a Fan!!
Homegrown Motorsports
Blown Euros
Wheel Whores
If you do mind manual paddle valves theres a cheaper way to peice together a kit because you have to replace all of the fittings given to you in that kit. trust me i got the same one...
I dont have any pics of it, but I am running UAS Aerosport bags up front, using their bracket kit, But for the air management it is all mounted in the spare tire well, This is the digital system I am using
75% of issues with air ride are from the install. Of course there are failure rates of components just like anything else. But faulty wiring or the placement of fragile components (ie air line) are the usual cause of air ride "issues"Last edited by SteveO@OpenRoad; 10-07-2010, 07:30 AM.sigpic
(888) 407-2997
>>>OPENROADTUNING<<<
Become a Fan!!
Blown Euros
Wheel Whores
I wouldn't say that . . .but it is ALOT more work. Running all that air line is not a lot of fun. i would rather spend the $400 and go analogOriginally posted by Oxer View PostManual "paddle" valves ftl...sigpic
(888) 407-2997
>>>OPENROADTUNING<<<
Become a Fan!!
Blown Euros
Wheel Whores
Instagram@jdjurhuus
