So i'm in the market for an E30 and I'm going to want to run it very low.
Currently running a Mk4 platform car and with an engine raise, the only thing i'm hitting is subframe which is not a problem. However, after researching it seems that E30 sumps are pretty dang low.
The general consensus seems to be that the smaller engines have the lowest sumps, with the 318 being the lowest. Is that right?
I'm on the lookout for either a 320 or a 325 anyway, and from searching around it seems that these sit the highest. Are there many problems with raising the engine on an E30? Obviously being a rwd car it's going to have more effect than on a fwd car, but is it possible to raise it enough to get it above the subframe?
Any help and info would be greatly appreciated!
can even see this sump has been welded up
