paint my car with 2K paint and clear?
  • paint my car with 2K paint and clear?
    Hi!
    i will soon paint my car at the garage. i will paint it white with a cheap 2K paint that is made for boats. I know whaat you think about that.. it´s a budget build
    well i want it shiny like a car paint. can i sand it down and paint the 2k, and then use clear coat? how will that look?
    Look good bro
    God bless this mess
      is the boat paint single stage?
      Hatchbacks, wagons... It's NOT all the same. You want in? Don't get a mazda 3, get a mazda 6 wagon. Don't get a wrx get a legacy wagon. and theres a reason the A3 isn't called the A3 avant... Scion does not make a wagon it makes a weird van, but no wagons
      Sincerely,
      The Wagon Mafia:Inner Circle
      P.S. Is your tail a wagon?
      Show cars are lame.
        yeah i think so
        anyway. italked to a few guys that used the same paint. they say that the result of just the paint (2 layers) and then just a little bit of sanding with 2000 and then polish it looks just like normal, glossy paint with clear
          I don't know anything about painting but this is from eastwoods site:
          1K Coating vs. 2K Coatings
          There is often confusion and misuse of terms when it comes to describing automotive coatings. Here are some brief definitions that we hope will dispel the confusion.
          NOTE: Typically the term "catalyst" is used separately from the terms "activator" and "hardener" (as in epoxy catalyst) because a catalyst does not have isocyanates.
          1K: This is a term used to describe a coating that does not require a hardener, catalyst or activator. For example, this term can be used to describe “single-component” paints and all of the aerosol paints we sell (with the exception of the Spray Max products). NOTE: You may have seen “1K” and “Single-Stage” used interchangeably. See definition of “Single-Stage” below.
          2K: This describes a coating that needs to be mixed with a hardener, catalyst or activator. This can be used to describe our Eastwood finishes, “two-component” paints and other urethane finishes.
          One/Single-Stage: Used to describe a coating that does not require a clear top coat. A single-stage coating may or may not require a catalyst, hardener or activator. Plus, a clear top coat may be added in many cases for enhanced durability or depth.
          Two-Stage: Describes a coating system that requires both base and clear coats. This is more commonly referred to as "basecoat/clearcoat" or "BC/CC". The coats of base and clear may or may not require a catalyst, hardener or activator
          so according to that 2k paint is not single coat paint, it would require a hardener and clear coat?
          For Sale - e24 Build thread
          Add me on Facebook
          Instagram @Dared_Turtle
            yeah 2K needs to be mixed with thinner to work it don´t need clear though
              2K paint just needs to be mixed with an activator. There are plenty of 2K paints that are single-stage (don't need a clear coat).
              That said, spraying a clear coat isn't any harder than laying down paint. Plus clear is super cheap compared to the actual paint.
              Word
                Originally posted by Pekå View Post
                yeah i think so
                The procedure you have described here ,I have also paint my car in the same way and now my car just shines ,If you have also paint your car in the same way then just tell what's the outcome of your car paint?.Does you got your car in the same way as you wanted?.
                  Sure, if you have lots of expirence paiting with both, or if you dont care that it looks like dookie. If this is your first time painting a car or something of that size with clear, you should practice alot first. Its not as easy as it seems to get a good clean even non orange peeled look. I think anyone can do it, it just takes practice.
                  Been paiting since I was 15 taught myself in my own garage. The first 4-5 jobs i did with clear were bad. Needed alot of work and sanding/buffing.
                  cheap/junk/fads/build
                  HVLP
                  4 LIFE
                    There are a lot of techniques when it comes to car painting. Spray painting is where a device sprays a coating such as paint through the air onto a surface. It usually used the compressor to compressed gas to atomize and direct the paint particles with the used of spray guns. How many times have you needed more information on tips to get a fast cash
                    payday loan and turned to a web search on instant approval payday loans?" Your search is over, all of the facts you'll need is at www.MatchFinancial.com.
                      this is how it turned out it still needs a wash.. i will repaint some stuff and i will sand it down and buff it. i think it will be nice!
                      Log into Facebook to start sharing and connecting with your friends, family, and people you know.
                        Looks good! I wasn't expecting that lol
                        Instagram - @choadyhighroller
                          haha
                          total cost of the paint was about 100$.. :P it still need a repaint on some spots cause i had to customise some stuff after painting like rear fenders and all that..
                          then i will sand it down and polish it up. this is by just painting and washing so i think will look alot better after some morte work
