I have a 190E with Bilstein shocks and Eibach springs, but the drop this setup gives you is pretty canadian. Most people run cut springs on the old Benzes... I want to cut maybe one coil, but I was wondering which part to cut. The top has the end flattened and ground down, and the bottom only has the end flattened. If I cut the bottom, I won't have the flattened end anymore. Is that the "right" way to do it (obviously cutting isn't the right way haha...) Thanks!
Cutting springs on 190E, how do I go about it
I've heard lowering springs are pretty useless, because they are progressive, they just won't be stiff.
I'm running E36 coilover shocks in the front and 3.5" coils cut from original spring. It slammed the hell out of it, but the ride is great.
1958 Chevy Apache shop truck build
Commonwealth
W201/W124 Control arms and bag brackets
http://www.commonwealthmotoring.com/ Air ride and custom parts
IG - Commonwealth_mf FB - https://facebook.com/commonwealthmotoring
So you're telling me I need a wood blade?Originally posted by dc4dave View Postcircular saw. some viagra. get it boy
I used an angle grinder. I lowered my 190E too much in the front. 2 coils is decent, but after that go with half a coil at once, if you cut too much, you can easily get thicker spring pads.Originally posted by Rocambolesque View PostSo you're telling me I need a wood blade?
Originally posted by Jay92 View Post
Are those 17" wheels ur running ? Did u keep the stock shocks or upgraded ?
Sent from my iPhone using Tapatalk
Yes. because those will have specific spring rates for the lower ride height.
Cutting stock springs will eventually increase the spring rate compared to when they were the original lenght. So when you keep stock shocks, you'll end up with very stiff springs, but really soft damping.Last edited by loekaaz; 03-08-2016, 05:50 PM.Lucas
