Cutting springs on 190E, how do I go about it
  • Cutting springs on 190E, how do I go about it
    I have a 190E with Bilstein shocks and Eibach springs, but the drop this setup gives you is pretty canadian. Most people run cut springs on the old Benzes... I want to cut maybe one coil, but I was wondering which part to cut. The top has the end flattened and ground down, and the bottom only has the end flattened. If I cut the bottom, I won't have the flattened end anymore. Is that the "right" way to do it (obviously cutting isn't the right way haha...) Thanks!
    Mint green Mk2 build
    Daily 190E build
    I've heard lowering springs are pretty useless, because they are progressive, they just won't be stiff.
    I'm running E36 coilover shocks in the front and 3.5" coils cut from original spring. It slammed the hell out of it, but the ride is great.
    Building a W124 Benz
      Nah, the Eibachs I have are linear rate. Which end did you cut? Top or bottom?
      Daily 190E build
        Cut the bottom of the spring. Flattened side will sit in the upper spring cup. Here's a pic of mine for reference. I think 3.5 coils up front and 3 in the rear.
        1958 Chevy Apache shop truck build
        Commonwealth
        W201/W124 Control arms and bag brackets
        http://www.commonwealthmotoring.com/
        Air ride and custom parts
        IG - Commonwealth_mf FB - https://facebook.com/commonwealthmotoring
          circular saw. some viagra. get it boy
          @davidcharloff
            So you're telling me I need a wood blade?
            Daily 190E build
              I used an angle grinder. I lowered my 190E too much in the front. 2 coils is decent, but after that go with half a coil at once, if you cut too much, you can easily get thicker spring pads.
                Are those 17" wheels ur running ? Did u keep the stock shocks or upgraded ?
                Sent from my iPhone using Tapatalk
                  Also wouldn't it just be best to get the h&r lowering springs ?
                    Yes. because those will have specific spring rates for the lower ride height.
                    Cutting stock springs will eventually increase the spring rate compared to when they were the original lenght. So when you keep stock shocks, you'll end up with very stiff springs, but really soft damping.
                    Lucas
                    Originally posted by LCG
