Hey
My current spring rates are 700F/750R. 6 inch springs on front and back. I have sectioned housings in the front so it sits nicely but my rear isn't low enough. That brings me to my problem. I want to get 4" springs on the rear but the highest spring rate I could find is 600lbs. Would I run into an issue with a 600lb rear spring? My car is around inch till it bottoms out so I don't have to much room for it to move. And should I be running the stiffer spring in the front? Most setups I see usually are stiffer up front since the engine is there.
I could run either a 700 or 750 up front and a 600 in the rear. Anyone see any problems with this or any suggestions?
