I've had my bags installed for a couple months now. I have the airlift universal air struts with manual paddle valves. Recently when I air out, an oily type liquid is coming out of only one of my valves. so i jacked the car up, and pulled the line out of the bag and a little bit of that liquid came out of the bag. Now i know ive heard that condensation can build up in your tank and stuff, but why would it only be coming out of that one valve?
Leaky valves?
Air Lift Universals are fed from the bottom, aren't they? I'd be popping that leader hose off and seeing if anything drains out of the bag. Just like the tank, condensation can build up inside a bag, and it's possible you're getting a mix of condensation and some kind of residue leftover from manufacturing.
I'm assuming that when you drain your tank, you're not getting that same kind of oily liquid?
Originally posted by Oh Damn, it's Sam View PostAir Lift Universals are fed from the bottom, aren't they? I'd be popping that leader hose off and seeing if anything drains out of the bag. Just like the tank, condensation can build up inside a bag, and it's possible you're getting a mix of condensation and some kind of residue leftover from manufacturing.
Inside the bag, just in the bottom, there is an o-ring that is lubricated with red grease.
At the same level of the feed tap. Maybe the fluid you got is a mix of water and that grease.
________________________________________________
is there a way to take it apart to figure it out? or a way to get it to stop coming out of the valves?
i mean im hoping its something like that. im worried that the strut is leaking oil. but the thing is that they barely have 1000 miles on them. and i dont beat up my car at all so i dont think its that, but i mean is that a possibility?
