Help! Need some advice ! Front bags aren't lifting Car! ( new to bags) :-(
  • Help! Need some advice ! Front bags aren't lifting Car! ( new to bags) :-(
    Well recently I purchased the new truhart bag kit for my 05 TL. Installed everything as described, but i have an issue with the front bags not lifting the car. If the car is on jack stands inflated to 80psi then if I take the car off the stands it's high, however once I let the air out sure the car drops but I reinflate the bags up to 140psi and the front doesn't go up one bit! .. however once u start jacking up the front again the pressure drops to around 20psi because I release the weight of the car off the bags! .. but why isn't this working as it should? I'm lost.. the rear works perfect! .. and no I don't have leaks, that's the first thing I checked ! Need some help guys
    Any help guys?
      Originally posted by Fastguy View Post
      ...but I reinflate the bags up to 140psi and the front doesn't go up one bit! .. however once u start jacking up the front again the pressure drops to around 20psi because I release the weight of the car off the bags!
      Ordinarily I'd recommend checking for binding and doing a quick calculation to estimate what your lift pressure ought to be based on the car's weight and the dimensions of the bags, and while I think it might be informative to do both of those things, the above quote is possibly indicative of something unusual going on here. Your bag pressures shouldn't be dropping *that* dramatically when you just start lifting the car with a jack, and it's making me wonder whether your pressure readings are correct.
      What management are you running, where are you taking your pressure measurements, and what gauge are you using?
        I have manual management, the kit came with 2 switches .. 1 front 1 rear, i know I know that's not good, this is why today I ordered the autopilot v2 management. The readouts I'm using a psi gauge that came with the kit. The issue is that once aired out no matter how much air I try to inflate it to the car does not go up.. it's as if the front is way to heavy for it to lift
          What kind of pressure gauge? Where are you taking your readings?
          This may very well be the case. I've seen it on some air ride kits for the E9X platform, where there just isn't really enough room to put a large enough bag to lift the car (at least not without swapping the LCA out for something different). It also may be that you're just not putting enough air in the bag to get it to start lifting. Some Honda suspensions require an obscene amount of air pressure to get them to lift.
          You can get a rough estimate of how much pressure you need in the bag to start lifting the vehicle by dividing the vehicle's front corner weight by the front suspension motion ratio, and then dividing that by the area of the top cap of the air bag. It's a rough estimate, but it'll typically get you within 10 psi or so.
            Are you running accuair? My friend had the exact same issue ,the main plug to the valve block wasn't seated all the way in, only a few mm in it.
