Hello,
I'm really new for all this bagging so please be kind to me
I recently bought Autopilot v2 management with dual 444 viairs and 2 air houses for the rear and 2 aerosports for the front.
Im trying to fit them into my e30 Touring!
I am having some issues with my coilovers and aerosport bags, i'd really appreciate if you could help me out a little bit. The issue is that the bag rubs my wheels pretty bad and it doesnt even go low enough yet.
I test fitted the coils after i assembled them and jacked my wheel up so i saw the rubbing. I am just wondering did i assemble them correct because the upper mount seems a little weird for me..
If i could attach the airbag into bc strut's upper mounting plate it would make things easier and i think wouldnt have wheel clearance issues anymore. This guy has done like that to his bc racings http://www.lxforums.com/board/showth...h-UAS-Air-Bags
Any suggestions what should i do to the upper mount? Should i get different upper plates to the coils and try to attach the bag into it or? I don't even know if i need the camber adjustment.. What should i do?
Here is a picture of my top plate and the spring plate between the bag and the bracket to the bag.. It looks weird and the bag could be alot more up so my wheels wouldnt hit the bag, am i correct?
Assembled
Rubbing
I already have 15mm spacer there, my front wheels are schmidt th-lines 8,5" with 195/40/16 tyres. Any ideas what should i try to do? Modify the upperplate somehow or buy a new one from somewhere or what
E30 where i'm putting the bags in, this picture was taken last summer while i drove it static
Thanks in advance!
I recently bought Autopilot v2 management with dual 444 viairs and 2 air houses for the rear and 2 aerosports for the front.Im trying to fit them into my e30 Touring!
Assembled
Rubbing
Thanks in advance!
