kocking and lowering problems
  • kocking and lowering problems
    ok guys new to air, just had elevel with twin compressors installed on airlift performance struts on my mkv jetta, but im having the problem of one side leveling out completely different too the other and a series knock coming from my fronts when i fill the bags for speed bumps and so on, it even happens occasionally when i hit a bump?
    also last night i pressed preset 3 on my remote which should be fully, up and while going over a speed bump it had decided to slam itself causing enough body work damage to my front and rear arch's and god knows what underneath!?
    like i said im new to air so please don't be hitting me with what psi or stuff im running in each bag as im completely clueless, il try and answer your questions the best i can to help me out!?
    anything is appreciated
    cheers
    Did you notch the frame on the passengers side?
    Lower than you......http://www.airliftperformance.com/
      thankyou for a replay mate, no mate i only notched the drivers side, also the kncock has started to happen on both sides now?
        I would check to make sure your sway bar links are good and everything is tight on the struts. Sorry I cannot help you out on the Elevel.
          already tried that one matey, im gutted
            When you are preset 3, is your car up as far as it can go (or close to it)? It seems like you are topping your struts out when hitting bumps at that preset. If that is the case, I would recommend setting your preset 3 a little lower so you don't top out the struts. Topping out your struts will cause them to wear quicker and can cause damage to the dampers.
