For me I just notched the passenger side frame, removed cut the upper part of my front fender liners and it has laid frame since the first day the kit was on. I have airlift rears right now but I'm switching to d-cups and re-5's soon, I have blown 3 bags with the air lift bags and brackets even after adjusting them to make sure the bag was centered.
So the problem with the fronts is that I asked for slam series and the shop ordered performance series fronts... I'm real happy about wasting my money...
I wanted bombers, and the owner said he could save me money if I went through him and not bag riders, but then he convinced me that he could save me more money if I went with airlift, and it seems like he did. He knew I wanted slams in the rear, so I figured he would just get slams for the front. I mean, I know it's my own fault just as much as his, but you would think he would have given me an option rather than assuming I wanted the performance fronts to go along with my slam rears... I'm just frustrated with this whole thing. So far they have snapped three sensors on the rear, and now one in the front went. I wish there were other places to go, but there just isn't a lot of places near me. I should have known better about this place when they mounted the tires on my saw blades backwards two years ago...
The owner emailed me back and said that he had heard some bad reviews about the slam series. Maybe it's a blessing in disguise until I can afford bagyards...
Wow man, sorry to hear about all your trouble.. Did you get everything sorted out with the front struts or are you sticking it out with the Performance? As for the rears, you got the older Slam kit with the tapered sleeve bags? That kit does have a lot of issues because you have to cut off your upper spring perch and if it isn't done absolutely perfectly, the bag will rub on your lower control arm. If you haven't installed the rear bags yet, you should definitely check out Air Lift's new Double Bellow rear kit.
