THANK YOU! This is uber helpful
BMW e23, e24, e28 DIY Air Suspension Solutions
This topic is closed.
thanks guys. you wont be dissapointed after your work. my car lays hard with the airlift setup all around. front crossmember and oil pan lays out flat on stock bubble tires....
Last edited by NegativeCamber; 10-22-2011, 12:28 AM.Originally posted by KielanI've had a lot more fun in my Dad's Prius than I care to admit.
BMW e23 build Thread
Just saw this Eric. Great build. Happy that I could pave the way. I wish your aerosport setup had worked. We spent a good amount of time trading ideas on that.
thanks Nic. Much appreciated on brainstorming with me on that aerosport setup. To those wondering, I probably could have made it lay on aerosports , but then would have had to use massive spacers for any wheel to be used, since the bag would essentially be behind the wheel.
how the car sits....
Last edited by NegativeCamber; 12-14-2011, 01:28 PM.Originally posted by KielanI've had a lot more fun in my Dad's Prius than I care to admit.
the UAS bag is that much bigger in diameter? im guessing these bags were designed to not expand?Originally posted by NegativeCamber View Postthanks Nic. You did enlighten me on many aspects of the setup. Much appreciated. To those wondering, I probably could have made it lay on aerosports , but then would have had to use massive spacers for any wheel to be used, since the bag would essentially be behind the wheel.
ahhh, i see.Originally posted by NegativeCamber View Postnah, about the same diameter. the issue is the UAS bag didnt collapse as much as I needed at the desired position. Airlift's bag is 3" collapsed, including the mount length.
3 " collapsed is awesome, cant wait to see where you take it man
