BMW e23, e24, e28 DIY Air Suspension Solutions
  • Dr. Satan
    Bookmarked. I think you've already answered all suspension related questions I could have about my e23.
  • NegativeCamber
    Now I see what you mean. There are two options: obtain the lower threaded sleeve, then all you would need to do is cut the strut housing and weld the sleeve to the spindle. As you mentione, the other option would be to shave the threads and toss them inside the strut housing. Then you would use your external coilover sleeve to adjust the height. The only question I would have with that configuration is if the stock gland nut would be able to hold down the shock.
    Also, keep in mind the shock shaft diameter. Not sure if your strut top would fit.
  • D Unit
    I PM'd Eric at bimmerforums, but anyone reason why BC dampers wouldn't work?
    These are 44mm.
    These are e28 dampers that use a 51mm damper. BUT, I called BC and they said their e30 system uses a 45mm damper. If I shaved the threads down to 44mm, any reason why it wouldn't work since it's already shorter and made for a higher spring rate?
  • NegativeCamber
    Originally posted by Grime View Post
    Hey Negative Camber, would an air ride kit for a e39 work on an e28? If not, why is that? I have no fab experience, so I can't put your genius to use.
    The e28 has the strut housing attached to the spindle. It cant be separated. On the e90 you can separate the strut from the steering knuckle.
  • bdkawey
    If anyone is interested i have devoloped a solution for airlift struts so that you can run camber plates. Ill be doing a run of them/group buy after sowo
  • bdkawey
    no, its completely different
  • Grime
  • Alpine 7even
    NegativeCamber Would you be interesting in building a kit for me? Using your exact setup? I know nothing about air suspension and your e23 has the exact setup I want for my e23 L7! I'd of course pay for your time and the parts you'd need!
  • Lance_2444
    Originally posted by NegativeCamber View Post
    forgot to add this cheezy iphone video to this thread. yes, i have the missing moldings.
    bagged bmw e23 - YouTube
    I love that you used Com Truise in this. It's a very pleasant car to look at!
  • Anders_w
    Hey did you use the Air Lift 75561 and 75563 on this E23?
    Regards
    Anders
  • JE BMW
    Nie. would love to get airbags on my e36, but paint has to be first
  • Nick475
    Thanks for getting back so quickly. I always forget to be specific, but for that last question, I was specifically talking about rears. I figured the sleeve wouldn't be strong enough for up front
  • NegativeCamber
    Originally posted by Nick475 View Post
    couldn you just swap out the spring on the stock strut with a rolling sleeve? i mean you probably wont get as low with the stock shocks but still
    edit. and if not a rolling sleeve, could you just use an aerosport bag?
    I haven't seen a sleeve that can be mounted over a strut like an aerosport. Even of there was, the max weight rating would probably not be up to par for the front end of a car. You can use aero sports with stock shocks. It most likely would ride like crap. The stock damping parameters of the strut usually doesn't control bag oscillation very well. I've read a bunch of complaints when people use that combination . It may not happen initially, but it probably will wear the strut down faster.
  • Nick475
  • Nick475
    thanks man
