Originally posted by nik
View Post
Been doing air ride since the early 90's when I swore off hydraulics ( which I'm back into now as well lol).
To answer your question I'd reccomend finding a suitable position that allows you to keep the longest possible legnth on the threaded rod. Consentrate more on when it's completely laid out that the sensor doesn't top out an crack...leave a bit of room at the top end of the sensors stroke, that gives room for error. I've honestly just barely cracked a couple of the sensors by mistake, but they always have worked after. I use those for mockup and use the customers afterwards. That's why I now leave the rod as long as possible.
By leaving the rod long you potentially maximize lift. In some instances I've seen the rod cut down so much the tires would just untuck and the ride height maximum was basically cut in half.
The system is very well made and seeing as it calibrates it's maximum height during calibration, overextension of the sensors is impossible.
It's a bit of a pain when you do it for the first time, but it's not that difficult. Just keep your eyes peeled and be open to different potential mounting locations.
However in some instances the sensors should be removed before placing the car on a lift. Some suspension setups may surpass the 2.75" range of the sensors, so for the 1 min it'll take to unbolt the lower attachment...it's well worth doing to be safe.
Here's a 58 impala I recently did.
Front setup
Rear
Locked up
Down flat.
This car will be on wires soon.
Trunk...ya I polished the tank.
Hope that helps...love this site.
