AccuAir Height Sensors Installed
This topic is closed.
  • #16
    Originally posted by vipTL View Post
    Hey hey here is my Sensor install on my 2008 Acura TL-S which should be similair to a TSX, first two pictures are of the front and the last is the rear, i will get a better picture next time i get the wheel off. Both front and back sensors are attached to the sway bar, we added a tear drop metal plate used a lock washer to ensure it doesn't get loose from moving up and down.
    Thats awesome, Thanks heaps dude, Makes my life a lot easier haha.
    Originally posted by anth
    • #17
      Originally posted by NegativeCamber View Post
      thanks for the info mike! im an electrical engineer, so its alright with me to get as technical as you can. its pretty close to as what i figured. good stuff. i'm waiting on some feeback to a custom setup i need done, then the next step is an e-level system. i hope to post my setup here by the end of the year
      Nice! Very cool, looking forward to seeing what you come up with! Keep us posted!
      Mike Alexander
      Director of Marketing
      Mike@AccuAirCS.com
      (877) 247-3696
      • #18
        Originally posted by Oxer View Post
        Hey Mike, Havent happened to do an Acura TSX by any chance? Shortly Ill be hitting you up for a kit for one, but the rear ends have a crazy 5 link rear set up, and although I havent had a great look, I thought I'd ask haha.
        this guy, full doing reasearch for me and everything <3 u
        • #19
          I can't wait to contribute something to this thread
          • #20
            deff be stopping back in here if i end up getting a wagon and bagging it...just looks like so much work...main reason of not adding e-level to my cabrio and just running switchspeed
            Insta Mintyhinrichs
            • #21
              VW Golf MK4
              What i got so far, i'll post the rear pic this week if i'm not lazy
              Taken from my build thread here: http://forums.vwvortex.com/showthrea...-Rocker-Switch
              Here how the sensor is fully extended and fully compressed on Raceland coilover, Hopefully the Airlift XL doesn't extend more or I'll have to cut a longer aluminum bar
              I had to mount the sensor arm backward to increase the tire/sensor gap when the wheel was fully turned left.
              and here is the other side
              • #22
                Originally posted by kilimats View Post
                :::::ITSHIM:::::
                qq
                if "life, liberty and the pursuit of happiness" doesnt include being able to buy a huge veiny motherfucker then the declaration of independence isnt worth the hemp it was written on.
                Originally posted by Jedidiah
                he speaks the truth.. he doesn't even have the -- -- eyes.
                • #23
                  and here is the rear
                  EDIT: the sensor travel was too small so i had to relocate the ball further in the rear
                  • #24
                    pics aren't showing up for me?
                    Mike Alexander
                    Mike@AccuAirCS.com
                    (877) 247-3696
                    • #25
                      Your work place most likely filter images from DROPBOX.com
                      That's where I host them
                      • #26
                        Works now, thanks! Lookin' good man.
                        Mike Alexander
                        Mike@AccuAirCS.com
                        (877) 247-3696
                        • #27
                          A question for all the guys with mk4 golf , how do you route the cable from the height sensor from inside the car to the front wheel arches
                          Cheers Kenny
                          • #28
                            http://forums.vwvortex.com/showthrea...-Level-Install
                            Here's a 5 routed through the wheel well (drilled and use grommet)
                            Mike Alexander
                            Mike@AccuAirCS.com
                            (877) 247-3696
                            • #29
                              Cheers Mike , I saw that on vortex , I was just wondering if there was a rubber grommet that it can be pass through like the rear
                              • #30
                                And here's the finished result (AccuAir + BagYard)!
                                brendan's install is by far one of the cleanest you'll ever see.
                                he's never broken a sensor, ever. then again, it took him about three months to finish the damn thing
                                I used to be famous.
                                somewhere between I want it and I got it.
