Thanks man. It doesnt bother me nearly as much anymore. I think the car still looks great as is, just not as stanced as I'd like. I'm gonna run it like this until the snow comes, then grab some coilovers and do it right. When that comes around, I'll raise the rear a little bit, and take my time to get it proper. Thanks for all your inputs guys, it's definitely helped me get my head straight on this.
Need help on 10" rear on 335i
Actually doesnt look as bad as in the first pic. Get some 15-20 spacers for the rear and that should fill it in some.
I wouldn't waste your money. Sport springs are pretty soft, you'll most likely rub like crazy if you did that and went wider. Just get coilovers with high spring rates and do it right the second time around.Originally posted by Eric the Ricer View PostNew idea, might snag some H&R Sport springs for the rear only. Supposedly the difference is about .3" (higher)
Hoping that if I toss those on, I'll have enough clearance to space the wheels out some? Thoughts?
The fender doesn't look even nearly as bad as I first expected. Haha That first pic makes it look painfully terrible. Also, grind out a little of the inside of the rear bumper. That's what I
did on all my e36s but then again I don't own an e90- but really it's not noticeable.
IG: @_olliee
Didn't know this got bumped. Been talking to Pete @ BC Racing, and gonna snag a set of coilovers sometime over the winter. I used to have a set on my Z when I had it. Once I get the height a little higher in the back, I'll be able to kick the wheels out to get some poke, then it'll be game on!
Thanks for the helps guys
drift
