You're going to have trouble with the 15x9 -12 rears if you don't plan on very aggressively pulling your fenders and running about -6 * camber.
for example, i am running a 15x10 +0 with a 205/50/15 and even with -6.5* camber it rubs on big bumps and hard turns. although, you can run a shorter tire, 195/50 and that may give you just enough to clear.
i'm still working on the fronts, but i am running the same size on the fronts right now and can't help but rub on turns. hopefully some more fender work next week will fix the problem...or else i'm screwed since they don't make 205/45's anymore...
