help with miata plz
  • help with miata plz
    hi guys got a 1993 jap import mazda mx5 eunos
    im looking to get some of these
    was wondering what the limits are for width and offset?
    i wanted to get 15x7.5 on the front and 15x8 on the rear offsets of 0
    or theres 15x8 front and 15x9 rear with offset of -15
    what will work n wont work im abit confussed with it all tbh
    Try clubroadster.net u will get more answers there.
    Uploaded with ImageShack.us
      No way you'll fit a -15 offset without a substantial amount of fender work. 0 offset will work an an 8" wheel with some minor pulling/rolling. Go to clubroadster like said above. There is a whole thread dedicated to wheel fitment there.
      Miata: 298.6whp - 270ft/lbs - 8500 RPM
      GC8: 320 awhp - 295 ft/lbs- 8250 RPM
      http://stanceworks.com/forums/showthread.php?t=23302
        Most Miata's you see are 15x8 et 0, its like it was made for the car, all you need to do is roll the fenders, and then maybe just a bit of pull, depending on what tires you run. 15x9 et -15 though, that is going to require a lot of fender work.
        - Kielan (Key-lin)
          It will work if you plan on running flairs.
          *Easily Impressed*
            Just to give u an example. I got these nice all chrome bassett wheels 15x8 -12 offset.
            I rolled my fenders and pulled out a little but they still were sticking out like a mexi-flush.
            IM trying to pull the flush-poke look but it won't happen unless I run like -4/-5 camber and that's too much. Tire wear will be between 6-7k miles. Not worth it.
            So those wheels are up for sale and I ordered a set of xxr 002 with 0 offset.
            Here are some pix to give u an idea
              15x9+0 w/ 195/45/15's on rolled fenders. No pull what-so-ever
              .... a -15 is possible if you get rear camber arms, but honestly miatas work best with non staggered setups. Get the same size all around and you should be happy.
              SLAMMED GARAGE
              slammedgarage@hotmail.com
                ^^^^^ spot on. Love the stance. I'll be getting my wheels on wednesday.
                How much negative camber u ran in the front and rear
                  max camber in the rear, and neutral camber in the front. All using the stock adjusters.
                  SLAMMED GARAGE
                    Do u know the numbers tho?
                      Someone help this guy out! The Miata is dope tho!
                      JDL-racing.com|RIZQ Built.
                      sickSTANCE-Slow&Low
                        ClubRoadster.com would have been a more suited website to ask this question.
                        Anywho, can't go wrong with an 8" +0 or a 9" +13. Those seem to pretty common setups that work well and look great. I myself recently picked up some new wheels which measure 16"x8" +0 and I wrapped them in 205/40/16 Falken Ziex ZE-512's.
                        MB Obsidian Black Metallic Crossfire SRT-6
                        Instagram - @osshwa
                          my car has 13x10 -20ish wheels on the rear. GOOD roll and lots of camber+slammed with stretched tires and i got them to fit with slight pull/no pull at all
                          15x9 -15 should work, it will be aggressive tho. and work will be needed. but not MAJOR work to the fenders.
                            the pic in my avi is 15x9 +3 hardly any pull. -15 should work with some work. ha
                              you should try a smaller tire and slam! it will work, i promise.
