So the wheels that I am purchasing ended up being out of stock; the color I wanted was only available in a 5x114.3 fitment and not in the 5x120 that I need. Anyways, the rep I spoke with offered to re-drill them while I am not a a wheel expert, I feel that I am somewhat knowledgeable and had some questions.
I asked if they fill the old holes and re-drill. He said they do. Then I asked if the wheel would have to be repainted in order to cover up the filled in holes. He said, the outside holes (the ones you see) wouldn't be affected at all. He said that the mounting pad holes are what will be filled/re-drilled.
This doesn't make sense to me....there is no way that 5x114.3 holes (starting at the face of the wheel) would line up properly with 5x120 holes on the mounting pad am I right? It sounded super shady so I just ended up going with a different finish but correct me if I am wrong but re-drilling would surely be visible from the face of the wheel right?
