3 inch/75mm spacers
  • 3 inch/75mm spacers
    So... I got fender flares knowing i'd need a spacer, not knowing i'd need to double my spacer size. I've searched around, and discussed stacking bolt on spacers with a buddy, and just realized that everything i found was for slip ons, and that a quick search here matches up with what my buddy said.
    Anyway. Stacking spacers is a no go. The question is, to save myself a ton of money, how sketchy is a 3 inch spacer? they're $80 a pair, and i have a set of mint Cobra R wheels, and almost no cash to get another set. The way i understand, the spacer isn't any harder on the hub than a set of wheels that'll get the fitment i want, but i've been wrong before. I'd need a -50 offset or something like that to run without spacers, but i can't find a set. and i haven't had time to measure for my backspacing.
    i don't know if you know, but 3" is more like 7620mm
    Floccinaucinihilipilification
      Pascal, you are a few decimal points off.
      You can run a 3 inch spacer without issues, as long as it is hubcentric on both ends.
        The only ones i can find are hubcentric on the hub itself, i can't find any with a lip on the spacer.
        but thanks guys!
          Adaptec Speedware will make any size/type you need.
          Motorsport Tech is your absolute number one source for wheel adapters, wheel spacers, and hub centric rings. We manufacture the finest adapters in the world, and we do wheel polishing, chroming, powder coating, and color matching, as well as sell wheels and tires at WHOLESALE PRICES.
            They didn't have my truck, so i emailed them. Hopefully i can get a set without spending more than $200
