Last summer, I picked up a set of CCW D15's that came with some stretched brand-X tires. Here's a side shot the day I mounted them, and a few others from the day I had picked them up:
Not wanting to spend more money at the time on new tires, I drove with them, as is, for a few months and just recently swapped over to my winter setup (MAsshole, here).
Now that the CCW's are off my car, I'd like to ditch the current tires and go with some proper fitting rubber. Here's where you all come into play. :dance:
CCW specs:
front - 18x9.5 et20 (current tire 215/35)
rear - 18x10 et25 (current tire 215/40)
I have a Pre-LCi 335i, lowered on BC coilovers. I have a beater truck that I drive often, but would still consider my E90 a "daily driver". I've done a ton of searching/research on this very topic, but have yet to find any concrete information.
Keep in mind that I'm willing to roll my fenders (and probably will have to, with the aggressive front fitment), and during the summer months, I'm not at the lowest ride height. I probably have another 1-1.5 inches to go down on my coilovers.
Lastly, I can adjust front camber with the BC coilovers, which should help.
But to avoid as much rubbing as possible, what tire sizes should I look at switching to? With my 162's, I was running 225/40/18 front and 255/35/18 rear and had no issues. But with the more aggressive offsets and widths of the CCWs, I know that won't work.
So let's hear it. What are the optimal tire sizes I should look for? Thanks in advance!
CCW specs:
