I need to repolish my lips but dobt want to take off the tires? Is it ok to take them out if I let the air out of the tires and remove valve stem corrs? Thanks.
Removing bolts without taking tires off?
How much stretch do you have on your tires?
In general, it wouldn't be something I'd be dying to do, since all that will be holding your rim halves together will be the sealant. However, if your tires have significant stretch (i.e. not any outward pressure coming from the tires) and you're not afraid to reseal the wheels if things go south, it's not liable to hurt anything.Last edited by Oh Damn, it's Sam; 01-09-2015, 05:16 PM.
205/40 on 18x9 and 215/40 on 18x10. Would be better if I left 4 bolts in so they hold the wheel together?Originally posted by Oh Damn, it's Sam View PostHow much stretch do you have on your tires?
Originally posted by Oh Damn, it's Sam View PostThe way I'd probably handle it is to pull a handful of bolts in one area, polish, put bolts back in, and move to a new area.I basically have to repolish the lips from ground up. I have to jave all the bokts out when sanding the lips. I can work around 4 bojts if thats the only safe way to do itOriginally posted by PROSTO. View Post205/40 on 18x9 and 215/40 on 18x10. Would be better if I left 4 bolts in so they hold the wheel together?
Go buy a few bolts with smaller head profile, specifically for this purpose. Button head should work fine.Originally posted by PROSTO. View PostI basically have to repolish the lips from ground up. I have to jave all the bokts out when sanding the lips. I can work around 4 bojts if thats the only safe way to do it
Use a few countersunk or flat head style bolts with a head size just larger than the holes in the lip. The low profile will be easier to polish around/over, and you don't have to worry about damaging your good bolts. You can get them at any hardware store... most likely find them with a straight or phillips head.
