Rebuilding SSR Agle Premiums
  • Rebuilding SSR Agle Premiums
    Hey SW,
    I've got a set of SSR Agle Premiums I picked up a few months ago and am ready to rebuild them for my very strange fitment needs and of course more wide and more lip!
    Currently they are:
    19x8.5 et38 (1.5 inch lip) (includes ~15mm of backpad) - also running a 32mm spacer
    19x9.5 et43 (2.5 inch lip) - also running a 38mm spacer.
    With spacers, I'm close to my ideal fitment the only thing i'd like is a bit more poke and then I'll work on the dialing in of suspension etc.
    So if my math serves me correct, I'd need the following to pull this off.
    I'm looking to build the fronts for 9.5. Which should be easy. Move the front faces to the 9.5 lip/barrel. By doing so this should bring me to ~9.5 et 20?
    For the rears, I'd like to go 11 1/2 with a 4.5 inch lip rather than the 2.5 inch and keep the current barrel. The end result should put me right at 19x11.5 et 18?
    Mainly my question is, where can I source the replacement lips? They are 40 hole step lips.
    Also, does my math seem correct?
    I've done all the test fitting needed to ensure these new spec wheels will fit and without spacers, the barrels do not rub on any part of the suspension.
    Thanks in advance for the help, I'm just trying to better suit myself and avoid any surprises.
    I've read through all the tutorials and this is where it got me.
    Here is a calculator for the ET:
    Use our calculators to find your wheel offset and backspacing, know if your tires will fit, convert tire sizes and bolt patterns from metric to imperial, and more at Custom Offsets.
    Do aftermarket(Triangle) lips work?
      I'm not sure if aftermarket lips will work. Thanks for the calculator.
      Any input would be appreciated.
        Measure your lips, bolt hole center to bolt hole center. Also, if you have the center out, measure the inner diameter.
          The wheels are currently on the Jeep, for the bolt hole to bolt hole do you mean across the lip? or the hole to hole side by side?
            Across, not side by side.
              I'll try to grab a measurement in the morning!
                16 1/2" from center of bolt hole to center of bolt hole.
                Just for reference, my lip measured at 3.5" in the rear from where the lip starts to the lip/barrel meeting spot.
                Only 2.5 is actually visible.
                  Bump!
                    Any help would be greatly appreciated
                      The 19" Triangle lips I have measure ~17.4 bolt hole to bolt hole. Bore is 16.9"
                      So no go there.
                        Well dang, so if triangles are a no-go will I need to source OEM lips?
                          Noticed something.
                          The lips I have are reverse, so the face is huge.
                          Triangle step lips have similar dimensions to what you posted:
                          Rim I.D. @ Bolt Flange: 17.500" / Bore: 15.900"
                            The current lips do have a step. But even that those are similar, they wouldn't fit. There's an inch difference in my bolt flange alone.
                            Originally posted by zoo View Post
                            Noticed something.
                              The Rim I.D. @ Bolt Flange is not bolt hole to bolt hole. It is the inner diameter taken at the flange area.
