currently have a set of 2 piece wheels and im looking at having more dish and having it sit a lot more aggressive.
They are currently 18x9 + 37 and from the mounting point of the face till the end of the rims is 3.5 inch (outer) and 5.5 inch (inner)
Was thinking off mounting the face the opposite way so now id have 5.5 inch on the outer side and 3.5 inch on the inner side.
Would there be any issues of having a rim with 3.5 inches inner barrel while outer is 5.5inches?
Also calculating the offset i have -15 as the new one as currently the offset is 37mm from centre (4.5 inches). With the current face bolted on 26mm from the centre (assuming 1 inch = 26mm) the hub meets the wheel 11mm positive of where its bolted to the barrell. With reverse as the face is being bolted 26mm negative of centre, with the 11mm positive of where the hub i get 15mm. would be easier to explain with a diagram - also i could be completely wrong so feel free to correct me.
Thanks
Thanks
