Is this a safe thing to do? Who is running their wheels like this? My cars not a daily driver but I do drive it often in the spring and summer months.
Reverse mounting BBS RS'
Hit me up for all your quality used bmw parts needs! http://properperformance.com/ IG: Lowlygent
Tags: None
At least on the set I had, the faces are actually sandwiched between the lips and barrels, but the lips and barrels were built such that they also mated together around the outer edge of the faces. So putting the faces on the insides of the barrels would leave a gap between the barrel and lip mounting surface that can't be brought together, and would be very unsafe.
its been done many times before. I wouldnt do it as its not seated fully on the wheel halves, but to each their own. I have a friend who has done it for years and no issues with NYC driving. Im not condoning it thoughsigpic
1982 euro porsche 930 turbo
Thanks guys I'm just trying to get that extra half inch so I can run a larger lip. A 2'' lip is much better looking than a 1.5'' lip.Last edited by DinanDave; 04-30-2013, 02:03 PM.Hit me up for all your quality used bmw parts needs! http://properperformance.com/ IG: Lowlygent
You can machine Your centers to accept that mount. The RS070 are made that way from factory, but the design of the wheel is also different.
Check Your wheels! If you have enough material, You can mate the lip and barrel with the rear mount configuration by machining the center on a lathe. Here is a photo of the RC041 center done to accept front mount configuration.
Here is a photo of regular RS070 rear mount configuration from factory.
Thanks man ill look into itOriginally posted by a112 View PostYou can machine Your centers to accept that mount. The RS070 are made that way from factory, but the design of the wheel is also different.
Originally posted by DinanDave View PostIs this a safe thing to do? Who is running their wheels like this? My cars not a daily driver but I do drive it often in the spring and summer months.This does not make sense. You will gain a ½ inch inner clearance, and push the lip out by the thickness of the barrel. If you reverse mount them.Originally posted by DinanDave View PostThanks guys I'm just trying to get that extra half inch so I can run a larger lip. A 2'' lip is much better looking than a 1.5'' lip.-
Instagram@jdjurhuus
Stretchsaurus and Pokemon.
Reverse mount meaning mounting the face behind the barrel... not the face in front of the lip or a front mount....Originally posted by Zic View PostThis does not make sense. You will gain a ½ inch inner clearance, and push the lip out by the thickness of the barrel. If you reverse mount them.Hit me up for all your quality used bmw parts needs! http://properperformance.com/ IG: Lowlygent
Won't reverse mounting them leave a strange gap from the lip to the centre, as in the centre will look sunken down from the lip? Obviously the standard sandwich mount leaves the centre and the lip flush with each other, but reverse mounting them will have the centre sit lower than the edge of the lip, which will look a bit strange won't it?
A buddy of mine is running his Oz Futuras like this and it looks fine. I know they are not bbs rs' but its the same concept.Originally posted by Beware View PostWon't reverse mounting them leave a strange gap from the lip to the centre, as in the centre will look sunken down from the lip? Obviously the standard sandwich mount leaves the centre and the lip flush with each other, but reverse mounting them will have the centre sit lower than the edge of the lip, which will look a bit strange won't it?
Originally posted by DinanDave View PostReverse mount meaning mounting the face behind the barrel... not the face in front of the lip or a front mount....I know that, and you should listen to me. By putting the barrel in front of the face, that normally is sandwith mounted. You will PUSH the LIP outwards, because the BARREL will be IN BETWEEN the FACE and LIP. Remember that the face will stay in the same place. its only the lip and barrel that move around, the wheel would also change width.Originally posted by DinanDave View PostA buddy of mine is running his Oz Futuras like this and it looks fine. I know they are not bbs rs' but its the same concept.
The Futuras are built that way standard.
Ill try and do a visual on this matter. a AWESOME paint photo coming up.-
Instagram@jdjurhuus
Hope this picture works, I tried to explain it real simple. Hope it clears up some confusion.
*edit, correction of the "FRONT MOUNTED" text. You will have less inner clearance around 1/4". tho the lip will poke ½" less, allowing persons to larger lips.Last edited by Zic; 05-10-2013, 06:34 PM.-
Instagram@jdjurhuus
*edit, correction of the "FRONT MOUNTED" text. You will have less inner clearance around 1/4". tho the lip will poke ½" less, allowing persons to larger lips.Zic thanks for the fantastic photo! I see what your saying now. I think that it would look dumb if I front mounted the faces. So I think I'll just stick with the normal sandwich mount. I wasn't thinking the geometry was like this so your photo helped alot. Thanks man. Oh and I love your E28 by the way!Originally posted by a112 View PostJust trivial FYI Not all Futuras are rear mounted, but Zic is making a valid point here.Hit me up for all your quality used bmw parts needs! http://properperformance.com/ IG: Lowlygent
