Chrome plating removal
  • Chrome plating removal
    I have some aluminum rims with the chrome factory plating on them. I googled' the heck out of this and come up with alot of differnet answers, any input would be appriciated.
    But, as well I am going to try different methods of removal, as to try and help other people who stumble upon this thread.
    So far I have used low quality paint remover.
    Results: Took away some of the clear coating but thats all.
    Sanded with 180 grit paper.
    Results: Takes both coats away down to a yellow primer. But takes along time, and sore hands.
    More to come...
    cheap/junk/fads/build
    HVLP
    4 LIFE
    Sandblasting.
      That was my first thought, but heard horror stories of the sand pitting/damaging the aluminum. So I thought of trying some not so destructive things first. I may still try this if all else fails. Some pics to come this weekend.
      HVLP
      4 LIFE
        Sandblasting doesn't work... tried having it done a couple times. It will take off the chrome and some of the nickel layer, but it doesn't get through the copper. There's a chemical process to remove chrome.
          Use high quality paint remover.
          cheap flights to india from uk
            Chrome should be removed chemically.
            Chris Lane - fifteen52 - Join us on Facebook
            chris@fifteen52.com 813.505.7910 - direct : 213.373.1552
            RML | 52 Wheels | KW | ST | B&G | Newing-Alpil | C2 | Air-Lift
              chamical removal. first chrome off then nickel.should not be that expensive to be done by a professional.
              Some photos regarding this issue:
              Start:
              Chrome removed: (nickel still on)
              All done, chrome + nickel removed, pure aluminium:
              After that paint & polish and you are all ok:
              Project car: MB 190E M50 Turbo build
              Now: MB W211 320cdi
              Ex:MB 190E M50, BMW E39 530d
                Is there any practical way for doing that at home?
                  for crome maybe, for nickel i bet not, even so i paid around 150€ for 4 lips and 4 center including centercaps.. Nickel plating needs pretty tought chemicals to remove.
                  Now: MB W211 320cdi
                    I have two sets of chrome wheels atm, and NO ONE in my area will remove chrome.
                    I've called every electro-plating place in town. Such a pain in the ass.
                    Originally posted by electricalbox
                    12 inches of goodness!
                      Acetone should remove chrome & nickel plating? not sure how much time will it take or does it harm the aluminium?
                      Weird i was wondering that all companies that does chrome plating does remove aswell..
                      Now: MB W211 320cdi
                        acetone will definitely not work. im a professional automotive painter, i've done a few old school bmx frames that were pretty peeled and pitted. i just sandblasted them and used a good acid etch primer made for bare metals. they've held up very well, however, they dont take the abuse that a wheel would take. just my thoughts...
                          Iron(III)Chloride is pretty good against chrome and the nickel layer but i don't now how it react with aluminium.
                          unchroming badges
                            to remove chrome they need to be acid dipped only way to get it down to bare aluminum most places that offer chrome dipping can also acid dip
                            http://www.facebook.com/parkhard
                            www.hardparkergarage.com
                              I've had various sets unchromed by a chrome shop; they won't re chrome the parts and one of those sets the aluminum really aged quickly after being stripped. Each set ran about $150 to be stripped.
                              Activity is not on my list of activities.
