I was told that running OEM length lug bolts would be safe with 5mm spacers. However, this kind of concerns me as I coated my OEM lug bolts with a light coating of anti-seize to see how many threads actually secured into the hub. When I installed the wheel/spacer and removed it, I saw that only 3-4 threads went into the hub. This doesn't seem too safe to me. Should I get extended lugs, or will this be perfectly fine?
When is it safe? Spacer question
