E28 Guys!
  • E28 Guys!
    I think I have my tire and spacer sizes figured out, but I want to make sure I'm on the right track;
    Front:
    17x8 ET20 with 20mm spacer and 215/40-17s
    Rear: 17x9 ET26 with 25mm spacer and 225/45-17s
    So that leaves me with ET0 at the front and ET1 at the back. I'm not 100% on the rear tire size, but I want a kind of meaty-looking stretch, especially since I won't be super-low. I'll be on Spax springs, and I may cut 1/2 or 1 coil off of the front. The rear I'm not worried about since they're pretty low, and the shocks are adjustable.
    Basically I want to know if the offsets I've chosen will get me flush or at least close to it without crossing over into pokeland.
    I know there are only a few of us, but anyone who has run a beefier setup on an E28, please chime in!
    -1993 535i/5 NA-T
    Did some more research, went with 215/45s on the 8s. Nexen N3000s have round sidewalls. Crap.
    They'll be going on the 9s, and I'll be getting some 205/45s for the front. That should be just about perfect for what I want.
    Up next is more drop and spacers.
    -1993 535i/5 NA-T
      I followed you here from MyE28. I'm also about to go SPAX and Billy Sports. I'm going to use 15mm spacers on a 17x8.5" ET 20 Mille Miglia II wheel. So I'll be ET 5. I think I could get away with 215-40-17, but I'll be safe and go with 205-40-17, that should help me with the rubbing and I won't have to kill my fenders too badly.
      If I don't like this look, I'll go with Borbet type As 17x8.5 ET 13 with the same 15mm spacers and see if that works better. The Borbets are just collecting dust...
      If I don't like that, I'll go with staggered style 66s (also collecting dust) with the same 15mm spacers with a 205-40 and a 215/45.
      I think with your 0 and 1 offsets, you'll need to run a 205-40 and a 215 45. Even that may be close. Roll your fenders and pray those SPAX springs are as stiff as people say they are...the M30 oil pans are soft as hot butter.
        Originally posted by CSBolger View Post
        I'll be on Spax springs, and I may cut 1/2 or 1 coil off of the front. The rear I'm not worried about since they're pretty low, and the shocks are adjustable...
        ...Up next is more drop and spacers.
        I'm definitely glad you're going for the more aggressive stance and choosing the spax springs. The more I look at them, the more they look very close to the ride height that mine is at, Brad is running 17" wheels though and his is the only car I've seen them on so I can't be sure how they would be with 16" wheels. Be sure to post some pics as soon as you get them in!
        Also just noticed this picture:
        I spy some matte green euro E28 in that shot!
        I will never get tired of seeing Borbet A wheels on E28s. I'm really liking that groupbuy on the spax springs that TCD is putting up, that will clean up the look on so many E28s! At the spax rideheight, which is close to mine, I haven't had to worry much about my oil pan. As long as I avoid the ridiculous stuff in the middle of the road (potholes, raised manholes, etc.), and take driveways at anything but head on, there's really nothing to worry about.
        I'm hoping to take my suspension to the next level by the summer. Hopefully we'll see a setup similar to B Rod's height:
        :drool:
          damn that is LOW. I wanna rock it like that with mine..what does he have on there?
            Hey Skip! Glad to see you over here.
            Plans have changed slightly - I'll be running 215/45s on the 8s, and 225/45s on the 9s. I have some 15mm spacers lying around, so I think I'll throw them on the back and see how I like them. That will put me at et11, so if it's good enough for me, I'll just roll with that, and probably get some 15s or 20s for the front.
            I should have my skid plate fabricated by the end of next week - no way in hell I'm risking that pan, I cracked one at stock height, haha!
            Please PM on MyE28 when you make some progress, I'd love to see what works best and how it looks on your car.
            Yup, I was there. I took over 200 shots, just haven't had time to edit them all, or upload the ones I did edit. I was the flushest BMW there...by default, haha!
            Brad's car has fixed camber plates in the front, and I think he said they raised it 3/4". Since my Bilstein Sports still have two more notches to go down, and it's already tucking tire in the rear, I think I'll just chop a bit off of the front springs for now.
            Spax will still happen, but this is cheaper and faster.
            Cut stock springs. I don't have the balls to do that. Especially without some kind of protection for the oil pan.
            -1993 535i/5 NA-T
              um....yeaaaaaa no good on that for me. Long Island is notorious for throwing stuff at you when you least expect it.
              Is that you or someone else whos makin that black anodized skidplate for E28s??
                Raceskids.com
                They don't list it, but they do have E28 plates. I'll be making mine.
                Quick update: 215/45s at et5 in the front (8") will be just about perfect as long as I calculate my drop correctly.
                A roll and maybe a tiny pull in the back will get me just about flush with the 235/45s that are on there now (9") at et11 - that should make 20mm spacers and 225/45s doable in the near future.
                So for now, I'm looking at;
                Front: 215/45 17x8 et5 - not quite flush, but damned close.
                Rear: 235/45 17x9 et11 - should be even closer to flush than the front.
                -1993 535i/5 NA-T
                  as of now Im looking into a set of concave TE37s, the Linea Corse wheels are not made in the size I want so I have to step down.
                  Going for 18s and a sick pull.
                    I've been proven wrong before (Kosei K1s come to mind) but I don't think TE37s will flow with the lines of an E28 at all.
                    18s would definitely be interesting though. Do you plan on going flush in the rear? It would require insane rake to pull off since the rear arches are so damned low.
                    -1993 535i/5 NA-T
                      I had a set of 17s next to my car the other day, and Im liking the way 17s look actually. Especially with the offsets I was planning to go, I need more tire to support the car. With Long Islands bad roads, if I pull tires on 18s then I run a big risk of bubbling a tire or popping it off the bead.
                      Ichiba makes 5x120-5x114.3 conversion spacers, with bolts and all. That opens up my wheels options a LOT, and I no longer have to wait 8 months to get a set of custom wheels shipped to find out they dont fit right. 5x114.3 at a 17x10 or 10.5 with an offset of 30, plus the 15mm conversion spacer, should leave me somewhere around 15mm.
                      I want to see some proof on an E28 on how far out I can go without seriously modifying the fender...15 in the back might still leave some room to go, but then again a 9" wheel et 11, my 10" wheel would be 12.5mm beyond where the face of your wheel ends. Im basing this on the fact that my wheel would be exactly 1" wider, so Im referencing adding a half an inch to the back and to the front of the wheel. One inch = about 25mm, so I cut that in half.
                      Then again, this is all based on if I get a set of wheels that are the same offset as what you are planning to run, then add an inch. Im prepared to roll the inner fender completely flush(even cut the lip out if I have to, but Id rather not get to that point). If you add 20mm spacers to the back to a 11, that now puts you at -9....negative offsets are the isht . My 10" wide wheels in the back would put me somewhere comparable to a -1.5mm offset of your 9" wheels with the 15mm spacer AND the 20mm spacer. Unless Im reading it wrong and you plan to do just 20mm spacers overall. Then that makes this whole calculation pointless! lololol
                      Those 540 wheels you have on your, car what offset are those?
                        Specs are up top: Fronts are 17x8 et20 (they're et0 right now) rears are 17x9 et26 (they're at et11 now).
                        With my rears at 17x9 et11 on a 235/45 the driver's side rear rubs over any moderate bump (or when someone is in the car). I'll be putting a 225/45 on in the next few days, then possibly the 20mm spacers, which would leave me at et6 in the rear.
                        Running negative offsets in the rear on a 10" or 10.5" wheel sounds like you'll be in Poke City to me. Austin's car (DaRedRocket) was at et-1 on a 9" wheel and he was right on the border of flush and poke in the back. A 10" wheel at -6 just sounds like too much to me.
                        Your calculations are off - I plan on running a 20mm or maybe a 25mm in the rear, not stacking the 15mm and 20mm spacers.
                        -1993 535i/5 NA-T
                          hm 9s would be practical...but i wonder if I can get enough concaveness with that and a lip.
                          Might just stick with 10s at +15 offset and go from there. I will think about it more tonight and post again after i spend an hour doing the calculations in my head....I think that if I left 10s in the back at +15, the face of my wheel would be 8.5mm past your face (im sunk in 4mm more than you, but add 12.5 to that I would be 8.5mm past the face of your wheel). That might still leave me a few mm shy of Austins car
                          could you take some pics of what your car looks like by any chance??
                            I'll get on pictures soon. It's been a busy few days for me, and the rain hasn't helped. I may do a small shoot today, though.
                            I'm not happy with my setup right now though; I have a 215/45 on the front (8" et0 after spacer) and a 235/45 on the rear (9" et11 after spacer). I want to get the 225/45s I have laying around on the 9s and swap the spacers front to back. Then I'll be at et5 in the front and et6 in the back.
                            Anyway, I could have pictures by tonight. We'll see.
                            -1993 535i/5 NA-T
                              sounds good to me..
                              The gf and I are waiting for the weather to clean up and get warmer (and NY to fix all the damn potholes in the roads) before we go get a new set of shoes for her E92 335....I have friends in Cali who sell LCs, and shes got her mind made up on a set of Dynas, 19x10 all around, 235/35/19....it pokes just a little bit, and looks very nice while doing so
