na, won't need that much sanding IMO. don't be discouraged.
Refinishing Work Meister S1 3P "progress thread"- need some help too!
Thanks for all your help man.Originally posted by C.Johnston View Postna, won't need that much sanding IMO. don't be discouraged.
I've got the first lip completely wet sanded, did 320-400-600-800-1000-1500-2000. Looks nice and smooth now with no scratches but dull.
So I have some brown polishing compound that came with my dremel kit that I bought a couple years ago. Can I/Should I use it? Or should I go straight to the Mothers mag & aluminum polish I have? Should I apply the mothers with the dremel and a buffing wheel or do it by hand?
Buy a meguir's polishing dynacone, and use it with an electric drill. That will have the high enough rpms to get a polished look, cutting the elbow grease in half.
Also spend more time sanding a making sure theres no sanding marks. Cause I can still see some in my lips but I'm glad how they came out.
It'd be cool if you color matched the faces Suzuka blue
Well I got antsy and just went through my own way..Just elbow grease and mothers. I tried using the dremel but it was giving an uneven polish.
Unfortunately my drill is 3 hours away at my parent's house, will definitely use it for the next lip. This one still needs a little more polishing but I'm pretty please with how it turned out.
