Refinishing Work Meister S1 3P "progress thread"- need some help too!
  • #16
    na, won't need that much sanding IMO. don't be discouraged.
    • #17
      Thanks for all your help man.
      I've got the first lip completely wet sanded, did 320-400-600-800-1000-1500-2000. Looks nice and smooth now with no scratches but dull.
      So I have some brown polishing compound that came with my dremel kit that I bought a couple years ago. Can I/Should I use it? Or should I go straight to the Mothers mag & aluminum polish I have? Should I apply the mothers with the dremel and a buffing wheel or do it by hand?
      • #18
        Here's how it is now
        • #19
          Buy a meguir's polishing dynacone, and use it with an electric drill. That will have the high enough rpms to get a polished look, cutting the elbow grease in half.
          Also spend more time sanding a making sure theres no sanding marks. Cause I can still see some in my lips but I'm glad how they came out.
          It'd be cool if you color matched the faces Suzuka blue
          • #20
            Well I got antsy and just went through my own way..Just elbow grease and mothers. I tried using the dremel but it was giving an uneven polish.
            Unfortunately my drill is 3 hours away at my parent's house, will definitely use it for the next lip. This one still needs a little more polishing but I'm pretty please with how it turned out.
            • #21
              Looking good!
              • #22
                looks good, now we are twins
